Rebuilding a CHNC I Collet Closer
23 Sep 2013 19:03 #39136
by BigJohnT
Replied by BigJohnT on topic Rebuilding a CHNC I Collet Closer
On a long shot I looked at my old photobucket account and found the photos.
s47.photobucket.com/user/johnplctech/lib...Closer?sort=3&page=1
The collet closer leaks air when open and I just unplug the hose if it will be open long. The CHNC uses a lot of air...
JT
JT
- PsychoTech
07 Apr 2021 18:13 #205273
by PsychoTech
Replied by PsychoTech on topic Re:Rebuilding a CHNC I Collet Closer
Hi there Big John T, I am having the same issue with my CHNC 1, and am curious if you may have gotten the dash numbers reversed in the first two o-rings you posted. When I search McMaster for 1879T23, I pull it up with a dash of 016 and when I look up the 9452k18, I get a dash of 010.
Do you still have these rings sitting around? I realize I'm responding to an 11 year old thread and am guessing you've tossed them or given them away by now, lol.
08 Apr 2021 22:48 - 08 Apr 2021 22:52 #205378
by BigJohnT
Replied by BigJohnT on topic Re:Rebuilding a CHNC I Collet Closer
Actually I still have the O-Rings.However the labels have all faded...
I would guess that the part numbers are correct however I do have slight dyslexia so number reversal is possible.
I can spare some of most of them...
JT
JT
Last edit: 08 Apr 2021 22:52 by BigJohnT.
- PsychoTech
26 Apr 2021 16:00 #207132
by PsychoTech
Thank you so much for the offer! But I've already ordered and received everything I need. Putting them on today. I'll update if everything fits or not, so future users/searchers can see if the dash numbers were reversed.
- PsychoTech
26 Apr 2021 18:56 - 27 Apr 2021 18:29 #207152
by PsychoTech
Replied by PsychoTech on topic Rebuilding a CHNC I Collet Closer
Alright... HOW ON EARTH did you get the bearing housing off?!?!? did you use some kind of puller?
I'm assuming I remove the bracket holding the closer to the... collet holder tube? I don't know what it's called. And then I remove the spanner nut at the back of the valve assembly. But the spanner nut just spins the closer. I tried putting a strap wrench on the closer but I can't get the spanner nut to budge. After the spanner nut is off, I assume I disconnect the air lines and then gently deadblow the whole assembly off the tube?
Last edit: 27 Apr 2021 18:29 by PsychoTech.
17 May 2021 22:54 #209284
by BigJohnT
IIRC the collet closer just slides out rather easy once you loosen the 4 screws that hold the collet closer to the spindle then rotate the top a bit to you and the whole assembly slides out of the spindle. Or I have no idea what your asking...
JT
JT
02 Oct 2023 16:20 #282072
by Loren
Replied by Loren on topic Rebuilding a CHNC I Collet Closer
BigJohn, I'd like to contact you but dont find a message option?
- Thank you received: 5946
02 Oct 2023 17:29 #282085
Replied by tommylight on topic Rebuilding a CHNC I Collet Closer
@Loren,
Ask here as every normal person.
Moderators: cncbasher
Time to create page: 0.495 seconds
