Hitachi Seiki VM-40 Retrofit
12 Jan 2014 13:32 - 12 Jan 2014 21:51 #42636
by bevins
Hitachi Seiki VM-40 Retrofit was created by bevins
I am starting a retrofit on a Hitachi Seiki VM40. The original control is not working but everything else looks good.
Installed LinuxCNC and I am using a 5i25 and a 7i77 which is up and running. I am programming and learning as I go.
Here are some pics of the machine as it sits now.
Last edit: 12 Jan 2014 21:51 by bevins.
12 Jan 2014 21:45 - 12 Jan 2014 21:49 #42654
by bevins
Replied by bevins on topic Hitachi Seiki VM-40 Retrofit
Started working on new control box to house the mesa cards and I/O and power.
Last edit: 12 Jan 2014 21:49 by bevins.
12 Jan 2014 21:45 - 12 Jan 2014 21:54 #42655
by bevins
With the ATC and P{LC, I am thinking I will run out of I/O on the 7i77. I will leave room to add an I/O board.
Last edit: 12 Jan 2014 21:54 by bevins.
13 Jan 2014 05:45 #42674
Have a look at the smart-serial boards.
Any one of these can be connected to the smart-serial port of your 7i77.
store.mesanet.com/index.php?route=product/category&path=83_88
There is a wide range of capabilities there. The 7i64 can handle significant voltage and current. (which is why it is so much more expensive)
Replied by andypugh on topic Hitachi Seiki VM-40 Retrofit
13 Jan 2014 20:37 #42698
by bevins
I don't think I would need the higher powered card. I will just be energizing relays. So the 7i84 will do fine I think.
13 Jan 2014 21:05 #42699
by bevins
More work done on panel.
The following user(s) said Thank You: newbynobi
14 Jan 2014 04:12 - 14 Jan 2014 04:14 #42712
by davo727
Replied by davo727 on topic Hitachi Seiki VM-40 Retrofit
Nice project. Thanks for posting it. What part of the world are you in?
Last edit: 14 Jan 2014 04:14 by davo727.
14 Jan 2014 04:16 - 14 Jan 2014 04:35 #42713
by bevins
I'm in Montreal, Canada
still learning the ins and outs of LinuxCNC struggling but getting somewhere.
Last edit: 14 Jan 2014 04:35 by bevins.
15 Jan 2014 10:24 #42800
by bevins
15 Jan 2014 20:38 #42817
by BigJohnT
Replied by BigJohnT on topic Hitachi Seiki VM-40 Retrofit
Very neat wiring! You don't see that often.
JT
JT
Moderators: cncbasher
