Lagunmatic 3516-SX Retrofit
20 Apr 2018 05:05 #109327
by giz
Replied by giz on topic Lagunmatic 3516-SX Retrofit
Thanks for the reply John. I've uploaded all the pertinent schematics here:
files.acrobat.com/a/preview/5765b1d6-b8a...a3-a9a4-8abf12ca28a0
The 24v and 5v power supplies that are feeding the 7i77 have isolated outputs, zero continuity with their input side when tested on the bench.
However I noticed tonight that when I connect PS outputs to the 7i77 I do have continuity between the input N and DC(-) on the 5v power supply. Recall input N is connected to chassis ground. I didnt have time to investigate but my first guess is that the ground connection is originating at the PC power supply and traveling to the 7i77 5v connection through the DB25 cable.
This may or may not be an issue, doesn't seem to affect the 7i77's ability to power up.
My extension cord test was done with an ungrounded cord and I did not connect chassis ground to the power supply. The PS was ungrounded. My extension cord was feeding the 24v and 5v power supplies and machines main power was shutoff.
Disconnecting all the 7i77 outputs is an interesting suggestion, I can test that tomorrow night.
- islander261
- Thank you received: 216
20 Apr 2018 14:12 #109334
by islander261
Replied by islander261 on topic Lagunmatic 3516-SX Retrofit
Giz
I think you have found the problem. I think that the PC power supply common DC connection is connected to chassis (safety) ground, this is not that uncommon. Check for the 5V return to N connection again with the cable between the PC and the 7I77 unplugged and plugged in. If the connection goes away when unplugged then the connection to chassis ground is happening in the PC. This is one reason I like the Ethernet connection cards, no galvanic connection between the machine and the PC.
20 Apr 2018 14:17 #109335
Replied by PCW on topic Lagunmatic 3516-SX Retrofit
PC ground is chassis ground
The 7I77s 5V side (encoders and analog outputs) share this ground
The 7I77s 24V side has no connection to the 5V side so if you see this connection,
you have connected the 5V and 24V side grounds together externally (perhaps by tying the 24V common to chassis ground)
- islander261
20 Apr 2018 14:29 #109336
by islander261
Giz, PCW
Well now we have the answer! The wiring posted clearly shows the 24V common connected to chassis ground.
The following user(s) said Thank You: giz
20 Apr 2018 15:16 - 20 Apr 2018 15:17 #109337
by giz
Based on my tests I'm fairly certain the 7i77 5v is grounding to chassis through the PC power supply (and therefore to the 24v common). My computer PS is connected to the existing power connector used for the old control computer. The PC power supply L/N/G are shared with the L/N/G going to my 24v and 5v power supplies.
So based on all that, I am hoping if I follow John's suggestion to unplug the DB25 connector from the 7i77 then my 24v power supply will continue working when I connect V(-) to common. This has been the crux of the situation - the 24v circuit had to connect to common/ground but everytime I did the power supply stopped working.
If that test is successful, then the question becomes "How should I power the PC?" I would prefer to use only the existing 3ph incoming power so perhaps an additional isolation transformer for the 3 power supplies? It's not clear to me how I might create an isolated ground with that setup.
Thanks a ton for all your help I think we're getting there!
Last edit: 20 Apr 2018 15:17 by giz.
20 Apr 2018 15:29 - 20 Apr 2018 15:31 #109340
Umm... There should not be any issue with the 5V side being grounded to chassis ground nor any need to isolate the 7I77 5V side from ground unless you have a ground loop issue (noise)
If your 24V power supply stops working when you connect 24V common to ground you have some issue with the +24V side wiring you need to resolve.
Floating the 5V to remove a 24V short issue in your system is very likely to damage components all through your system
Last edit: 20 Apr 2018 15:31 by PCW.
- Mike_Eitel
- Thank you received: 185
20 Apr 2018 15:31 - 20 Apr 2018 15:32 #109341
by Mike_Eitel
Replied by Mike_Eitel on topic Lagunmatic 3516-SX Retrofit
I had a quick look in your shema. The ac side of your first transformer is connected to ground. If this ac voltage is rectified in any graez both sides, plus or minus, will shortcut one have wave if connected to ground. You can not have grounding in both sides of a graez rectifier. You would need complete floating electronis ... With every shilding you risk a shortage.
m5c
m5c
Last edit: 20 Apr 2018 15:32 by Mike_Eitel.
20 Apr 2018 15:39 #109342
by giz
Sorry - I misinterpreted your last response to mean my wiring was wrong because my 24v and 5v circuits shared a ground. I've had no issues with the 5v the way it is - the sole issue now is that when I connect 24v (-) to common, as required by the way the relays are setup, the PS shuts down.
So John's original suggestion to disconnect all 7i77 outputs to start with seems on point. I'm not sure if it matters but most of the outputs, currently, are active as soon as the 7i77 is powered on.
Fixing this issue if obviously over my head so I really appreciate your patience and help.
20 Apr 2018 15:52 #109344
_No_ 7I77 output should be on at power up
This either indicates a major wiring error of some kind or that the 7I77's 24V output section has been damaged
20 Apr 2018 15:54 #109345
by giz
Let me double check tonight what the behavior is... when I tested in the past my LinuxCNC config was running which could have activated the outputs.
Moderators: cncbasher
Time to create page: 0.202 seconds
