Elumatec SBZ 130/01 retrofit
21 Oct 2020 06:21 #186791
by Benno
Replied by Benno on topic Elumatec SBZ 130/01 retrofit
Thank you very much, that sounds great.
My Email Provider says attacements up to 70MB are no problem. If you want to try it, maybe in 2 emails. Here is my address " benno (at) bandel . at "
best regards
best regards
- Topic Author
- Thank you received: 5930
14 Nov 2020 22:58 #189401
Replied by tommylight on topic Elumatec SBZ 130/01 retrofit
Uploading to google drive, sorry for the delay.
17 Nov 2020 20:43 #189618
by Benno
Danke!!!! Thank you!!!!!!!!!
The Pictures are very nice.
10 Jul 2022 17:16 #247025
by tmoeti
Replied by tmoeti on topic Elumatec SBZ 130/01 retrofit
Good day Tommylight. Tirelo here in Botswana.
I just saw this thread and I think you did a great job in successfully installing a new different control system on the machine that was not working.
I have the same machine at work "Elumatec SBZ 130/0". The problem with it is not moving on one of the axis.
I sincerely request that you also share with me the wiring diagrams of the machine, that would help in diagnosing the machine, right now I am not sure where exactly to touch,
Your help will be highly appreciated. Whatsapp: 0026777863001
- Topic Author
10 Jul 2022 17:30 #247028
Hello Botswana, or the best place on earth to drive according to Top Gear !
I will gladly send them, if i can find them.
The following user(s) said Thank You: tmoeti
10 Jul 2022 17:59 #247031
by tmoeti
Thanks in advance sir. It is the best.
11 Jul 2022 06:41 - 12 Jul 2022 14:51 #247059
by tmoeti
Good day.
for sending via googledrive.... Thanks.
Last edit: 12 Jul 2022 14:51 by tmoeti.
- Topic Author
11 Jul 2022 17:52 #247091
Sending files right now, check your whatsapp.
Enjoy.
P.S.
Delete the e-mail from the post above.
Enjoy.
P.S.
- Topic Author
12 Jul 2023 00:12 #275245
Lately visited this place and this machine is still working all day long, just working harder cutting 10mm wide slots on 6mm thick metal! Directly drilling with that 10mm end mill!
I am amazed it has not disintegrated by now.
The only thing that failed, several times, is the PC. The rest never had a single issue.
And yeah, they never fixed the toolchager, it has a lot of wear so occasionally fails to lock in place.
At least this one is kept a bit cleaner, they found out the hard way how it is to not have this machine!
Will take some pictures probably tomorrow and update here.
Thank you all who helped with this and other stuff i do.
Moderators: cncbasher
Time to create page: 0.169 seconds
