Brother TC-225 / TC-229 adventure!
22 Nov 2017 20:23 #102215
by laserK
Replied by laserK on topic Brother TC-225 / TC-229 adventure!
You're my hero! I totally missed the labels on the PCB. The relay board is mounted on the very left behind the circuit breaker and the labels are shadowed by the relays.
- ihavenofish
- Thank you received: 83
22 Nov 2017 20:29 #102216
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
its a pretty organised machine, if you do it right, you literally alter nothing on the machine from stock, and just reroute a few cables to the mesa (or whatever youre using).
23 Nov 2017 10:56 - 23 Nov 2017 11:21 #102254
by laserK
You said you still haven't figured out a way to swap limits for the ATC. Did you have problems with muxing the limits as above? To me that looks like the most elegant solution. Much less configuration than a virtual W-axis.
this is from another thread
.ini:
[AXIS_2]
MAX_LIMIT = 0
MAX_LIMIT_TOOLCHANGE = 200
postgui.hal:
loadrt mux2
addf mux2.0 servo-thread
setp mux2.0.in0 #<_ini[AXIS_2]MAX_LIMIT>
setp mux2.0.in1 #<_ini[AXIS_2]MAX_LIMIT_TOOLCHANGE>
net extend_z_max motion.digital-out-10 => mux2.0.sel
net z-max-limit mux2.0.out => ini.2.max_limit
change.ngc:
M64 P#10 ; enable off-limit movement
G53 G0 Z[#<_ini[CHANGE_POSITION]Z>]
G53 G0 Z[#<_ini[AXIS_2]MAX_LIMIT>]
M65 P#10 ; restore z max limit
thanks!
Last edit: 23 Nov 2017 11:21 by laserK.
- ihavenofish
23 Nov 2017 21:04 #102272
by ihavenofish
i think that is what im looking for actually but i couldnt find an explanation of how to use it. i am trying to do SOFT limits in this case. the hard limits are only for emergency stop. the soft limits awe the travel ranges, which in this case would be 7"-17" (give or take) for the normal z travel. then swap 17" for 21" do tool change.
im gonna upload my hal/ini files tonight, and the toolchange.ngc. we'll see if we can finally manage to get this going correctly.
23 Nov 2017 22:23 #102277
by laserK
Could your tuning problem be electrical noise due to shared ground between field IO and logic? From what I've measured the relay board has it's own ground (labeled P.G. - power ground??) different from the controller ground (L.G. probably logic ground, connected to the case). Maybe you've connected them by wiring a servo signal to the 7i77 field IO.
Looking forward to your config files!
- ihavenofish
23 Nov 2017 22:32 #102279
by ihavenofish
the servo drive is connected only to the enable +-, +10-10 and the 6 encoder pins. there is no other connection. there is a ground in the cable which has been left where it was on the cabinet. the drives are in no way connected to the relay board, only IO is on the relay board via ribbon cables. if there is a connection, it is one that's always been there.
noise on the line, and missed encoder pulses due to noise is definitely a possibility.
from memory, if i push the table by hand, the encoder feedback seems to be not as smooth as it should. its been a while though so i dont remember anymore.
- ihavenofish
24 Nov 2017 04:58 #102282
by ihavenofish
alrighty, here's some files
The following user(s) said Thank You: iamnot.romeo
- Thank you received: 1369
24 Nov 2017 14:22 #102289
Replied by Todd Zuercher on topic Brother TC-225 / TC-229 adventure!
Here is how I think I would attack this.
I would set up the soft limits for the full travel including tool change length. Then for the regular travel length I would set up something using the near component to trigger a user message and machine pause for the 17" travel. Then during a tool change it wouldn't be too difficult to disable the user limit you just created.
24 Nov 2017 18:21 #102307
by laserK
Why not setting the limits to the regular workspace? If a tool change is requested the upper limit is increased such that the spindle can travel to the ATC area. After the tool change the spindle goes down and the original limit is restored. Or am I missing something?
- ihavenofish
24 Nov 2017 18:24 #102308
by ihavenofish
youre not missing something, thats exactly what i want, but i have not yet figured the correct method.
im 99% sure what you posted will do it, but i will need to see how to implement.
inside the toolchange.ngc you would need to trigger the z upper limit change. i have to get back into this on the weekend, and try to remember where i left off
but, we still need to tune the drives first, or this is all for nothing.
Moderators: cncbasher
Time to create page: 0.461 seconds
