Brother TC-225 / TC-229 adventure!
15 Oct 2022 18:46 #254186
by billykid
Replied by billykid on topic Brother TC-225 / TC-229 adventure!
Thank you for your quick answer. the app I have already downloaded and installed, I soldered rx and tx and gnd because I did not have the connector but it connects and you can set all the parameters. rs2a03a "0" al0w00 however this abbreviation (the zero highlighted) stands for serial-only encoder. since I have a 400w delta with serial encoder I was tempted to try it but surely they will have different protocols I think.
it was for playing ... for my little cnc i used 7i40 and dc motors with 5000 ppr closed loop encoder and i am fine.
- ihavenofish
- Thank you received: 84
15 Oct 2022 18:49 #254187
by ihavenofish
Replied by ihavenofish on topic Brother TC-225 / TC-229 adventure!
if its seriel it has to be one of the r or q motors with serial encoders (usually an F in the motor designation if i remember)
sanyo drives can ONLY run with the specified sanyo motors and sanyo will refuse to help with any non standard config (including using brother specific sanyo motors)
15 Oct 2022 19:00 #254188
by billykid
01 Dec 2022 21:08 #258261
by pikis
Replied by pikis on topic Brother TC-225 / TC-229 adventure!
Can someone help me with ATC encoder wiring?
I'm using Mesa 7i77.
When I connect positive and negative wires of encoder as in Original I/O all my encoder wires for inputs are Negative and I can't use that for my 7i77 sinking inputs.
If I switch positive and negative wires then Encoder is not working but wires for inputs are positive.
- ihavenofish
01 Dec 2022 23:01 #258268
by ihavenofish
I don't remember anymore.
All i remember is there is one wire per sensor (5 total) that goes to the mesa. These were the same wires on the ribbon control cable. The powering of the encoder had been left "as is" and it all just worked.
01 Dec 2022 23:34 #258270
by pikis
Yes there are 5 wires for sensors and 2 wires for powering. If I leave powering "as is" these 5 wires for sensors are Negative...
Maybe it's possible to reverse inputs polarity somehow?
Like with Uln2003 for the Mesa 7i77 Outputs..
02 Dec 2022 14:34 #258319
Replied by andypugh on topic Brother TC-225 / TC-229 adventure!
Don't reverse the encoder power supply wires. At best it just won't work. At worst it will never work again.
I am a bit puzzled by their being 5 wires. Is one a shield/gnd?
What are you measuring them as "Negative" relative to? If they are pairs then they are likely to be differential pairs so you should see a pulsing voltage _difference_ between them as the encoder rotates.
- ihavenofish
02 Dec 2022 16:32 #258331
by ihavenofish
This is a bcd "encoder" wheel. It has 5 optical sensors. 4 are for bcd encoding. One is a deceleration track.
I am not really sure the issue here though. I never unwired mine from the original control. Just hijacked the 5 inputs off the old cable and they worked.
It is possible that reversing them destroyed the photo sensors and now it won't work.
02 Dec 2022 16:55 #258336
ULN2003 is no help here, it's a low-side drive item too.
A transistor (PNP) on each channel might do the trick:
electronicsclub.info/transistorcircuits.htm
See "PNP transistor switch[/b]
load switched on when IC output is low"
Though it might be possible to pull-up the inputs with a fairly high resistor and then have the encoder pull them down. I think I would experiment with that first (10k between the +5V encoder supply and the output pin). Once you can at least see a voltage swing you can adjust the resistor to make it a big enough swing.
Ah, right. Suddenly it makes a lot more sense.This is a bcd "encoder" wheel. It has 5 optical sensors. 4 are for bcd encoding. One is a deceleration track.
- ihavenofish
02 Dec 2022 17:12 #258337
by ihavenofish
None of this was needed on mine. If the machine side power is correct, then it should just work.
They are suggesting it needs a sourcing input, and that is definitely not the case.
Moderators: cncbasher
Time to create page: 0.299 seconds
