New Eagle Conversion
16 Feb 2017 23:18 #88088
Replied by PCW on topic New Eagle Conversion
If the drives drift when LinuxCNC is not powered you have a dangerous situation
This means you do not have the drive enables properly controlled by LinuxCNC
I would fix this before proceeding further
17 Feb 2017 01:23 #88093
by lakeweb
Replied by lakeweb on topic New Eagle Conversion
Hi Peter,
The servos did not drift when linuxcnc is disengaged. They were balanced when I pulled it from the Anilam. I was just answering that I could zero when engaged, I fully expected I could; but then it is not balanced when disengaged. I will leave it balanced for disengaged as I don't want it to drift when linuxcnc is disengaged. Is there any way to set an offset for the 7i77 when it is suppose to be idle? And I did a lot more checking. I get that 7.3 mv offset even when it is not plugged into the servos.
Do you have an idea about the ferror I've posted?
Thanks, Dan.
Thanks, Dan.
17 Feb 2017 03:53 #88098
again:
The drives MUST be disabled before LinuxCNC starts and is in the Machine-on state
If you have any state where the drives continually drift, this mean the drives are enabled but
the feedback loop is not in control. This should NEVER happen and indicates a dangerous condition
- Thank you received: 5926
17 Feb 2017 12:20 #88106
Replied by tommylight on topic New Eagle Conversion
Dan, as PCW stated twice, do not do anything before you get the servo enables correctly wired, most probably just swap the wires to enable.
Drives sbould normaly drift slowly when enabled.
Please read again the part about preparingfor tuning, i mentioned not to connect all drives at the same time. One by one, strictly.
17 Feb 2017 15:53 #88117
by lakeweb
Hi Tom, Peter,
There is no drift. I created a drift because peter asked me to balance while the servo signal was active. I did and put it right back. The servos are not drifting. I'll unplug Y and Z and that puts me back to the ferror shown on the hal scope. In the end I'll switch the servo power from F2 if the offset from the modulators can not be balanced. The servo rack has no other way to disable the drives, it is all or non.
The only possible way to control the servos seperatly would be to hack the rack and bring out the limit sense from the drivers.
ServoDynamics_1525
Best, Dan.
ServoDynamics_1525
Best, Dan.
17 Feb 2017 16:06 #88118
So are you saying that the drives are disabled (and therefore cannot drift) when:
1. LinuxCNC is not running or computer off
2. When LinuxCNC is running but in the machine-off state
17 Feb 2017 16:22 #88120
by lakeweb
Hi Peter,
There is no disable other than to cut power to the amps. When LinuxCNC is in the off state or the computer is off, there is no drift with the amps powered. There never was drift right out of the box.
17 Feb 2017 16:44 - 17 Feb 2017 16:44 #88123
The drives enables _must_ be controlled by LinuxCNC as a safety issue
SD1525 drives have a active low disable ( pin 8 on the controller connector)
These should be grounded by a normally closed relay contact until linuxCNC is
controlling the motion
Last edit: 17 Feb 2017 16:44 by PCW.
17 Feb 2017 16:52 #88124
by lakeweb
Hi Peter,
This is not wired on the rack. The Anilam just powered down the amps. I am planning to do the same.
17 Feb 2017 17:00 #88126
OK then the drive power down must be controlled by LinuxCNC or it is not safe
Moderators: cncbasher
Time to create page: 0.123 seconds
