Z axis control for a waterjet
26 Mar 2017 16:28 #90295
by antonyvm
Z axis control for a waterjet was created by antonyvm
Hello Team,
I was wondering about the Z axis control for a water-jet.
Like a plasma, the z axis follows the g-code and should be able to take manual corrections for the variation in the thickness.
Is it possible to introduce an up and down button in the interface, or is there a solution already?
Thank you,
Antony.
Thank you,
Antony.
- Thank you received: 5926
26 Mar 2017 18:24 #90305
Replied by tommylight on topic Z axis control for a waterjet
For using buttons, use any THC plasma config except ones for THCAD, it will work manualy only as it will not be controlled by gcode while it running.
26 Mar 2017 18:31 #90307
by antonyvm
Replied by antonyvm on topic Z axis control for a waterjet
The Z axis has to retract and come back to cutting position as per the gcode.
But after the initial positioning we would need to give small corrections to the position while cutting.
The on screen buttons can be avoided, could this work with an input to the controller?
One input for up and another for down.
26 Mar 2017 23:46 #90322
Yes, i did mean physical buttons and yes you can conrtol and home Z axis as usual while not cutting, at every cut start the THC hal component takes over Z axis so it can only be controlled from physical buttons ( THC sends up and down commands to Z axis ).
forum.linuxcnc.org/49-basic-configuratio...hc-config-that-works
There you have everything you need and a user who did exactly what you are asking.
Regards,
Tom
Regards,
Tom
Moderators: cncbasher
Time to create page: 0.087 seconds
