MEWAG with Bosch Rexroth Indramat DM 4K 1101-D drivers
03 Nov 2017 13:48 #101259
by JohnW
MEWAG with Bosch Rexroth Indramat DM 4K 1101-D drivers was created by JohnW
This horizontal milling/deep drilling machine, from about 2002 or so, has 3 Bosch Rexroth Indramat DM 4K 1101-D drives with non fibre optic connections to what looks like a VME rack. There is a PC front end which connects to the VME crate via a serial connection.
I am wondering if I can connect to the drives using LinuxCNC? I don't seem to be able to find much out about using the drives outside of the system as is. Any info or pointers appreciated.
03 Nov 2017 17:19 - 03 Nov 2017 17:19 #101278
Replied by andypugh on topic MEWAG with Bosch Rexroth Indramat DM 4K 1101-D drivers
DM 4K 1101 seems to be incremental encoder + Sercos command input.
www.lsa-control.com/catalogo/066029_105_...tionmanual_bosch.pdf
That's not as convenient as it could be.
A google search seems to suggest that all is not lost, some people have made it work, and there is even an academic paper on the subject.
Last edit: 03 Nov 2017 17:19 by andypugh.
The following user(s) said Thank You: JohnW
03 Nov 2017 21:09 #101290
Replied by PCW on topic MEWAG with Bosch Rexroth Indramat DM 4K 1101-D drivers
They seem to be available with either Sercos or Analog, at least the manual mentions the two interface options
03 Nov 2017 22:59 #101295
Yes, but the part number quoted suggests Sercos.
10 Nov 2017 19:39 #101628
by aventtini
Replied by aventtini on topic MEWAG with Bosch Rexroth Indramat DM 4K 1101-D drivers
you can take the servos interface and put a analog i think part code for analog is DDS 1.2
15 Nov 2017 05:56 - 15 Nov 2017 05:59 #101818
by Knaller
Replied by Knaller on topic MEWAG with Bosch Rexroth Indramat DM 4K 1101-D drivers
Good morning
try this link to Bosch Dokumentation
brmv2.kittelberger.net/borexmvz2-interne...=10540&remindCcat=on
On this side different language dokumentation
MDM Drive
MDM Drive
Last edit: 15 Nov 2017 05:59 by Knaller.
Moderators: cncbasher
Time to create page: 0.244 seconds
