Linear encoder strip suppliers?
04 Dec 2017 23:34 #102684
by idea
Linear encoder strip suppliers? was created by idea
Request for suggestions of suppliers for 480 lpi / dpi linear encoder strip? up to about 300lpi is easily available from ebay and alliexpress but so far i've not identified where to get higher resolution strip.
- Thank you received: 1370
05 Dec 2017 03:31 #102690
11 Dec 2017 23:07 #102948
Replied by andypugh on topic Linear encoder strip suppliers?
If you are in the UK, possibly: www.machine-dro.co.uk/high-accuracy-magnetic-linear-tape.html
12 Dec 2017 17:07 #103015
by idea
Replied by idea on topic Linear encoder strip suppliers?
Thanks for both suggestions, I was looking at optical only, but magnetic seems to be just as good, and may be a better fit for integrating into my machine.
Do people know of US suppliers for 1mm pole length magnetic strip? I'll need about 40omm total length, and prefferably 5mm wide.
12 Dec 2017 17:51 #103024
Replied by Todd Zuercher on topic Linear encoder strip suppliers?
First thing that pops up with google.
www.sra-measurement.com/high-accuracy-magnetic-linear-tape.html
The following user(s) said Thank You: idea
- ihavenofish
- Thank you received: 84
12 Dec 2017 19:46 #103032
by ihavenofish
Replied by ihavenofish on topic Linear encoder strip suppliers?
AMS AS5311 magnetic encoder. 488 micron resolution in SSI serial mode, x4 for incremental (under 2 micron). you can buy the dev mini board from mouser or direct from AMS for $20ish.
Bogen makes the adhesive backed tape, can be had in 40/10/3 micron/m precision. 40 micron comes in a roll, 10 and 3 are in 1m strips. you can call bogen usa direct to buy small quantities. my 10 micron strips were about $60 a metre. 3 micron isnt worth the extra money i dont think, at least not with the ams readers. the bogen tape is used with renishaw readers as well, used on many high end cnc's (dont ask me why they charge so much on those machine, the bogen guy doesnt know either)
drawback to the ams reader is that youll need to make some form of mounting block / housing. but if you have a cnc machine already, its easy.
i have not yet used mine, i intend them to go on my brothers.
12 Dec 2017 20:38 #103040
by idea
Yes, i've been looking at the AS5311, to go on a custom PCB with the end stop opto-sensors to mount within the X-Y carriage of the Proxxon MF-70 mill. The AS5311 is 1.95um incremental resolution (usual assumptions) according to the datasheet. $11ea for the bare chips on mouser.
The DRO-MG-TP-05-HA tape is the 'machine DRO' product and i had an email back from them that it is 2mm pole pitch, so 1mm spacing so should work fine. available in the UK from machine DRO and from sra-measurement in the US. Looks like the best bet at $70/m or GBP50/m in the UK.
- ihavenofish
12 Dec 2017 20:43 #103041
by ihavenofish
that tape is 20 micron precision, for more money than the bogen 10 micron. just to point out.
13 Dec 2017 15:18 #103083
by idea
That's true, thanks for pointing it out
02 Jan 2018 19:01 #103957
by idea
I'll order the sra product as i only need 400mm total (its a small machine) and Bogen have a $100 minimum order plus shipping.
Moderators: cncbasher
Time to create page: 0.241 seconds
