Lathe AC servo spindle motor
11 Jul 2019 07:57 #139075
by russkinch
Lathe AC servo spindle motor was created by russkinch
Hi everyone. I have made a CNC lathe which works very well, thanks to a lot of help from this group. It currently uses a 3 phase AC motor with a VFD. It only goes forward but I can control the speed in the software and gcode. I am rebuilding the machine, making it stronger and heavier and want to change the motor so I can do forward and reverse, as well and position. I understand it would be setup as C axis like the commercial lathes, but was wondering if anyone has done this, and if its even possible. I am looking at some AC servo motors on Ebay, like this one -
AC20V~80V HSS86 Hybrid Servo Driver + NEMA34 Closed-Loop High Speed Stepper Servo Motor 8N.m 0~3000RPM
Any ideas or suggestions? The reason for the position requirement, is in the very near future I will be adding either live tooling or a Y axis to mill. It is mainly small parts in brass, bronze or aluminium.
Thanks and hope someone can assist. This group is really great.
11 Jul 2019 08:04 #139080
by pl7i92
Replied by pl7i92 on topic Lathe AC servo spindle motor
hi a setup like in this video
its on his page
its on his page
11 Jul 2019 09:34 - 11 Jul 2019 09:35 #139085
by russkinch
Replied by russkinch on topic Lathe AC servo spindle motor
Hi. Exactly what I would like. Do you do the setup? The link on your YouTube page doesn't work unfortunately
Last edit: 11 Jul 2019 09:35 by russkinch. Reason: Added more info
11 Jul 2019 09:36 #139087
by pl7i92
if you got a YT account write him
there is also a homepage with Mail to get direct contact
he is also here in the Forum
with his name
with his name
The following user(s) said Thank You: russkinch
12 Jul 2019 15:38 #139178
Replied by andypugh on topic Lathe AC servo spindle motor
Assuming you want to be able to run the spindle at full servo speed, and also want to be able to mill-turn, you will need rather a lot of torque.
For a given material, cut depth, tool size and work diameter it should be possible to calculate the required motor torque using one of the feeds and speeds calculators (I know that the FSWizard app, at least, calculates cutting force)
I rather like the idea of using vehicle air-conditioner clutches to swap between two belt ratios for this sort of application. They are rated for about 30Nm.
Moderators: cncbasher
Time to create page: 0.092 seconds
