Sinumerik controlpanel with Linux CNC
13 Feb 2021 23:16 - 13 Feb 2021 23:17 #198747
by Onkelmat
Sinumerik controlpanel with Linux CNC was created by Onkelmat
From the first time thinking of doing a retrofit on my mill, I was wondering how to design/create a nice sturdy controlpanel with all the button you need. The best design I can think of, is one of the Siemens Sinumerik control panels.
I´ve read some manual of one of those and there was a almost easy pinout of the two 40pin connectors on the backside. Could be possible to use them ?
Last edit: 13 Feb 2021 23:17 by Onkelmat.
14 Feb 2021 01:33 #198770
Replied by andypugh on topic Sinumerik controlpanel with Linux CNC
Is it a keyboard matrix?
14 Feb 2021 22:20 #198867
by Onkelmat
Replied by Onkelmat on topic Sinumerik controlpanel with Linux CNC
I think the small panel had even a Pinout written in it´s user manual, but i wonder if it´s so easy why no one did mention it yet. I have the feeling i´m missing something obvious.
The big panel with screen would be even cooler since you have all you need together in one package. But regarding the amount of buttons i think siemens did some magic so you just can´t salvage it that easy.
Does anyone have sinumerik panel lying around and could check ?
14 Feb 2021 22:23 #198870
by Onkelmat
14 Feb 2021 23:22 #198880
What is the pinout?
One obstacle to using this sort of thing is getting the pins on the panel to issue keystrokes to the system, but I have a solution to that working.
What is the pinout?
15 Feb 2021 18:41 #198955
by Mud
Replied by Mud on topic Sinumerik controlpanel with Linux CNC
They're not cheap! New at least...
I have the first one to hand if you have an easy question. It's destined for an 840D, so no plans to work out the interface.
16 Feb 2021 15:48 - 16 Feb 2021 15:48 #199075
by Onkelmat
Could you try one button and see if there is any reaction on one of the connectors ?
Last edit: 16 Feb 2021 15:48 by Onkelmat.
16 Feb 2021 16:23 #199082
by Mud
The MCP is sat in a box with no power to it - if you have a pin out I can check for continuity across a shortlist of pins of interest (for example), but I don't have enough play time to reverse engineer it by guessing.
17 Feb 2021 09:27 - 17 Feb 2021 09:38 #199138
by Mud
See attached for details of MCP 398C.
PS - would assume X20/X21 are PROFINET.
Last edit: 17 Feb 2021 09:38 by Mud.
17 Feb 2021 14:30 #199157
by Onkelmat
wow that panel looks brand new !
Moderators: cncbasher
