LPKF ProtoMat S62 Retrofit Advice
- maltandmake
- Topic Author
25 Feb 2021 13:53 - 25 Feb 2021 13:54 #200096
by maltandmake
LPKF ProtoMat S62 Retrofit Advice was created by maltandmake
Hi, I picked up an LPKF ProtoMat S62 and am hoping to get it back up and running using LinuxCNC. I've done a bit of reading but think I need a push in the right direction. I’ve listed some information below but my hope is to run in with a Raspberry Pi and a Mesa 7c81. I’m not sure if I can interface directly with the original controller or if I’ll have to add in new drivers etc.
Can anyone suggest a good way to go about this?
Details below:
The original controller (LPKF SMCU II) drives the X and Y axis, receives input from the X and Y limit switches as well as the main door safety switch. It also has outputs which are designed to control a dust extractor.
There’s also a connector that goes to a DAC1005 (I think runs the spindle, Z axis and ATC motor) labelled LOCAL COM and pinouts:
CAN-H
CAN-L
GND
SYNC-H
SYNC-L
GND
PE/EARTH
Image of the controller
I’m not at all familiar with CAN bus but I think that’s the communication protocol it uses.
Similarly the SMCUII has an RJ45 connector (labelled CAN-A/CAN-B/RS232) with pinouts:
CAN-H
CAN-L
GND
NC / (RS232 TxD)
NC / (RS232 RxD)
GND
GND
NC
As a quick background:
The machine was designed to cut prototype circuit boards and has an automatic tool changer setup with 10 slots for tools, vacuum hold-down/extraction combination, 62K rpm spindle, fiducial recognition camera, all in a sound proof (maybe) box.
The original setup:
Brochure
X-axis and Y-axis
Schneider Electric BRS366HS0005
Z axis - Vexta 2-phase (model c9641-9212KGM) driven through a gearbox - 2.8V, 1A, 0.25deg/step
Driven via a DAC 1005 ?using RS232
ATC/Clamping motor
Maxon 114954 (24V DC) again controlled via the DAC1005
Camera
uEye UI 2410se-m-gl with a USB interface info
Controller
LPKF SMCU II
Details below:
CAN-H
CAN-L
GND
SYNC-H
SYNC-L
GND
PE/EARTH
CAN-H
CAN-L
GND
NC / (RS232 TxD)
NC / (RS232 RxD)
GND
GND
NC
The original setup:
Brochure
X-axis and Y-axis
ATC/Clamping motor
Camera
Controller
LPKF SMCU II
Last edit: 25 Feb 2021 13:54 by maltandmake. Reason: links
25 Feb 2021 15:46 #200103
Replied by Aciera on topic LPKF ProtoMat S62 Retrofit Advice
It looks like your drives use CANopen. Linuxcnc does not support CANopen.
At least not directly, apparently there have been users who have used EtherCAT as a go-between to CANopen. That path however will not be an easy one as there will be limited support for something as "exotic" as that :
forum.linuxcnc.org/24-hal-components/223...iver?start=110#49794
A much easier route would be to replace the motordrives. Although with 3phase steppers the choice will be somewhat limited. I'm also uncertain about the kind of encoder feedback in your system (seems either incremental or resolver).
- maltandmake
- Topic Author
26 Feb 2021 10:34 #200181
by maltandmake
Replied by maltandmake on topic LPKF ProtoMat S62 Retrofit Advice
Thanks for the advice! I thought that might be the case but didn't want to throw away the existing controllers in case I could interface with them directly. Guess it's time to figure out how to communicate with the spindle and ATC motor!
01 Mar 2021 00:27 #200490
Replied by andypugh on topic LPKF ProtoMat S62 Retrofit Advice
I suspect that the only difficult part of getting CANOpen working with LinuxCNC is the hardware interface.
It would need to be something realtime. In practical terms that means connected by PCI, maybe the Mesa UART or (though I hate to suggest it) the Parallel port.
All can be driven directly from HAL in realtime.
It seems that there was an EPP to CAN bridge on the market until a couple of months ago:
www.computer-solutions.co.uk/gendev/can-dongle.htm
PCI and PCIe CAN interfaces exist, but are definitely not cheap.
USB to CAN is very easy to find (I use one extensively at work) but that won't work with the LinuxCNC realtime layer.
How much of a project to you want?
- maltandmake
- Topic Author
05 Mar 2021 09:42 #201088
by maltandmake
Let's put it this way... I was expecting to have to completely gut the machine, replace the spindle, drivers, leadscrews... so if I can keep everything and just communicate with the existing controller that's be great!
Probably cheaper than my original plan! Do you have any suggestions/recommendations?
It looks like controltech.uk.com/collections/peak-syst...nterfacesControlTech UK has taken on most of the Computer Solutions products (or similar enough stuff)
I think my current barrier in the project is not understanding how the communication is going to work. I'm hoping that's just ignorance about the CAN protocol. Is there a standard way in which 'actions' are sent like in g-code or will I have to reverse engineer everything?
05 Mar 2021 10:08 #201090
Having found potential hardware, the next thing would, indeed, be the protocol.
Do you have the documentation for the drives? I would rather expect that all that is needed is a CAN packet to be assembled with ID for the drive and the position to move to.
Do you have the drive documentation?
There has been some recent discussion on the mailing list (but not in the context of realtime control)
sourceforge.net/p/emc/mailman/message/37203425/
And, from a long time ago:
sourceforge.net/p/emc/mailman/message/26045690/
But it seems he got no replies.
It might be worth asking General Mechatronics if they have anything: www.generalmechatronics.com/linuxcnc.html
- maltandmake
- Topic Author
05 Mar 2021 10:27 - 05 Mar 2021 10:27 #201094
by maltandmake
Unfortunately not. The X and Y are controlled from the manufacturers proprietary controller (SMCU II) and don't have separate stepper drivers. The SMCU II also communicates with another box - DAC1005. There is some documentation about this ( www.microsys-e.com.tw/webfiles/66b0614f-...0e-6f6bec4d1231.pdfl ) but I'm not sure if that's enough.
I have managed to get it moving using the LPKF BoardMaster software (albeit only just!). Since there are two RJ45 ports on both the SMCU II and the DAC1005 I wonder if there's a way to send commands from the boardmaster software and monitor what's happening via the other port? I guess once I've got the IDs for each component then that's a step in the right direction.
Last edit: 05 Mar 2021 10:27 by maltandmake. Reason: links
- maltandmake
- Topic Author
05 Mar 2021 16:42 #201105
by maltandmake
In case it helps anyone (future me included) the DAC 1005 uses CANopen (CiA 402) between 125 kBit/s and 1 MBit/s with 1MBit/s being the factory setting. LocalCOM is a proprietary protocol.
(as per www.microsys-e.com.tw/webfiles/66b0614f-...30e-6f6bec4d1231.pdf)
07 Mar 2021 00:41 #201237
To be honest, if you don't have the packet structure of the CANOpen packets documented lack of hardware and drivers is the least of your problems.
- Mike_Eitel
- Thank you received: 185
07 Mar 2021 09:22 #201265
by Mike_Eitel
Replied by Mike_Eitel on topic LPKF ProtoMat S62 Retrofit Advice
It s very long ago when I tried to do can-open via can. <99...
If I remember right you had to have a startup phase in which you had to define what values you want to address and where they are.. Everything is and has to be configured.
That was no fun. And we used nice driver cards, not cheepo, from Hilscher.
Beeing you i would not try that road.
m5c
Mike
m5c
Mike
Moderators: cncbasher
