Pressbrake CNC Control Setup Questions
27 Apr 2021 21:32 #207269 by andypugh
All in all, it looks like the zip file contains an old version of the files, as the error:
/usr/bin/gladevcp:223: RuntimeWarning: missing handler 'incrments'
makes no sense with the current file version.
27 Apr 2021 21:52 #207272 by cmorley
Making HAL input pins, the gladevcp way will automatically be polled and call functions.
28 Apr 2021 00:02 #207281 by andypugh
I should have said, the reason that I didn't just send an updated version is that it is all broken now, in the middle of adding homing.
28 Apr 2021 00:59 #207282 by EW_CNC
I think that we need to have a think about safety.
I've been giving this some thought. Jogging the ram is probably one of my main concerns. I'm waiting to see how you have the config working.
The control for the ram is the foot control and/or a simultaneous two button hand control. These switches and the e-stop button are in series with a normally closed hydraulic solenoid valve. This valve is normally closed for ram down and one-way checkvalve for ram up. So that if the estop is pushed while it's running, the ram will rise.
Jogging the ram will not be possible only with software. I would like to keep it like this.
28 Apr 2021 09:36 #207296 by andypugh
Clicking a jog button in the GUI puts the machine in Jog mode.
At the moment, at that point is moves the ram according to the jog scale setting and changes in the jog-counts input. The assumption is that there would be a jog-pendant with an MPG. When you say that jog mode doesn't work, were you manipulating the jog-counts pin? Or were you trying to jog with the foot switch?
It would be fairly simple to ensure that it only jogged if the foot switch was pressed, and could only exit jog-mode if the foot switch was released. Ram behaviour on exiting jog mode would need to be decided. (stay where it is, or raise to top?)
Or do you want to jog with the foot switch? I have my reservations about that.
28 Apr 2021 12:11 #207301 by EW_CNC
I wasn't understanding your jog setup. I was trying to jog it with the sim up down buttons.
I agree a jog-pendant with an MPG is the way to go. It will give far better control than the foot switch for jogging.
Should I add an extra switch to open the hydraulic solenoid valve while jogging or would it be best to let it as it is with the foot switch needing to be pressed to jog. Either way would work for me, but would adding another switch be a safety issue?
I believe I would want the ram to stay where it is when exiting jog mode.
I do have a separate ram up button that is connected to an input. Should this button be used?
Sorry, I feel like I make this complicated for you!
28 Apr 2021 22:45 #207338 by andypugh
You should be able to see jogging in action by using "setp" with the jog-counts pin.
Something to think about. This is all in HAL, so it is easy to set it up so that any number of inputs can enable (and, also, disable) jogging.
I agree that seems best.
Again, with a bit of HAL it can be arranged for both inputs to work.
I only took this on because it looked like an interesting project :-)
The following user(s) said Thank You: EW_CNC
08 May 2021 01:06 #208274 by EW_CNC
I have been using the simulation with jogging. I think it should work very good.
Are there any suggestions for adding a jog wheel? Just a simple MPG wheel mounted on the control panel or a full MPG pendant? At this point I feel that the ram is the only axis I will regularly need to jog, but I might be missing something.
Do you have a config ready for me to test on the actual machine? Sorry I'm not much help with the component, or with homing the axis.
E W
08 May 2021 03:47 #208284 by rodw
Thought I'd put my nose in here seeing i have a pressbrake with this controller on it.
icontrol.net.au/
You may like to watch some of the videos.
Whilst it has all sorts of free form drawing tools on it, the tech says its all a bit of a wank for the sales department and everybody just uses the bend list. I have to agree with him too. Basically, you just take a drawing from solidworks or Fusion360, and enter the dimensions and angles on it. The hard part is to decide on the bend order. I just write a number on each bend on the drawing and enter the dimensions in that order.
My brake only has the X axis (backstop) and the Y axis (vertical) bender and it has a bottom up action. The Y axis is set to zero at the top of the V.
My take on this machine is that its a simple XY CNC machine with a hydraulic ram attached. From what I can work out, the Y axis servo simply moves a stop sensor on a screw as per AP0204 diagram on this page.
icontrol.net.au/PressBrakeApps/
Bends are entered where 180 degrees is flat so a 45 degree bend is entered as 135 degrees. There is a bend adjustment column and the tech set that up to under bend by about 3 degrees becasue every piece of steel can be a bit different. So I always start with a -3 degree adjustment which should be close to the angle I want. (eg 90 degrees)
The Ram descends (or ascends on mine) until the position limit switch is triggered. Sometimes a dwell is set. Then the ram is retracted.
You specify the material you are bending, the thickness and the tool and bottom V geometry. Tools can be loaded from a library.
So all in all, you really just need to do some maths to determine how far the Y axis should move to give the desired angle given the V widths, material thickness and material type (steel, stainless, ally). I think that maths should be readily available.
Hope that helps....
08 May 2021 22:44 #208344 by EW_CNC
Rodw, Looks like a nice control setup for your pressbrake. Thanks for sharing!
My first experience with bending was on an up-acting Adira pressbrake.
The ability to have a tool library and specify material thickness would be nice, but at this point just a basic setup will cover my needs.
Most of my jobs are custom fabrication and repair jobs, so at this time I don't have the need to save a lot of jobs as repeat jobs.
My existing pressbrake has adjusting nut stops (like ap0203) with a mechanical readout. If this project works out I might wish to update it too sometime.
My experience is that sometimes you don't know how much use you have for the extra option, or the improved machine until you have it. Then you realize you could hardly do without it!
Moderators: cncbasher
Time to create page: 0.269 seconds
