lux turn cnc retrofit spindle upgrade
04 Mar 2022 17:29 #236366
by Navanod
lux turn cnc retrofit spindle upgrade was created by Navanod
first time posting:)
I've recently got myself and old lux turn cnc lathe and am in the process of a retrofit with linux cnc. Im looking at using one of the mesa cards probably the 7i76e and I am trying to get some advice on which motor driver for the spindle to upgrade to. The old spindle was a 450w dc motor but the driver board is missing and while the machine has the pully for a spindle encoder including a dangling timing belt this is a missing element.
so I am thinking of a more modern way to be able to achieve threading and constant surface speed cutting.
I've looked at one 1.2kw ac servo drive that apparently is using modbus over rs-232 /rs-485 and I am wondering how I am going to be able to achieve the control I would need with the 7i76e.
Has anyone such experience with such a servo drive for the spindle and the efforts Im going to have to go through to get this working? Ive seen other ac servo motors on aliexpress that use a 0-10v input but these dont get stocked in the EU presently and Id like to avoid long waiting times.
As for the rest of the machine its using 2 steppers for the main axis and another stepper for an 8 turret tool changer.
05 Mar 2022 00:11 #236385
Replied by andypugh on topic lux turn cnc retrofit spindle upgrade
LinuxCNC can do threading and CSS with any motor. In fact it can do threading with the spindle turned by hand.
I would suggest keeping the existing motor and sourcing a suitable drive from eBay.
Then find an encoder and fit geared 1:1
You could use something like a 750w three phase motor and VFD., though that will have less low-speed torque than a DC motor or a servo.
05 Mar 2022 00:14 #236386
Does that servo drive on Aliexpress support 0-10v control? If it does then you could use the 7i76 spindle control digital pot. That keeps everything real-time, which is nice for CSS
My lathe uses RS485 and a usb dongle to control the spindle and it is clear that sometimes spindle speed control is slightly laggy.
05 Mar 2022 09:21 - 05 Mar 2022 09:45 #236405
by Navanod
Replied by Navanod on topic lux turn cnc retrofit spindle upgrade
Finding a pwm servo driver at 90v is slim pickings in ebay unless I get it from the us..then the price is mostly the same and I'm stiuck with a system that's not easy to repair down the road. The encoder though would be easy. I can also buy a DC motor driver like inise on the milling machine"optimum bf20" but then I'm going to also need a breakout for isolation for the 0-10 v and I'm not sure how to deal with direction without a little hacking. The AC induction motor is possible but the form factor at the power requirements mean housing it externally and then adding a brake is also more challenging.
Last edit: 05 Mar 2022 09:45 by Navanod. Reason: Spellong
05 Mar 2022 09:48 #236410
by Navanod
Good question on the pwm input. I've just got the manual sent to me somill go through it now and have a look. I suspect that implementing both modes of operation could be good..I think others have done the same in the past but I'm not able to find the info of driving both step/dir and pwm yet.
05 Mar 2022 10:12 #236411
by Navanod
attached is the pdf manual for the drive, I am yet to really go though it but I think posting it can serve to help others who are looking for it.A1- SVD15 manual in PDF formatits split into 2 parts because of the file size
05 Mar 2022 11:21 #236418
by Navanod
On page 20
10V~+10V 。 Analog voltage input port.
Speed or torque control used to receive
speed or torque instructions. Voltage input
range -10V~+10V.
Not sure how I'm going to generate that +-10v as I'm guessing the standard has been the 0-10v
range -10V~+10V.
08 Mar 2022 22:00 #236716
by Navanod
had more time to look through the manual, looks like either it can use an analog input or step/dir.
Now to pair it with a bunch of hardware
any decent alternatives to the 7i76E for high speed encoder feedback? - by alternatives I mean ones that are available:)
I've not set up an electronic enclosure before and I am sure there is a ton for things that this is going to need apart rom the stepper drivers I have
Probably more isolation or noise filtering for a servo motor like this Imagine.
09 Mar 2022 23:53 #236795
There is a lot of hardware available for -10 - +10V control but generally aimed at controlling all the motors that way.
The 7i76 has a 0-10V output. How important is reverse rotation to you?
If the servo drive can accept step/dir input then that is probably easiest. LinuxCNC HAL can be configured with "velocity mode" stepgens, that produce pulses at a controlled frequency rather than posiiton control.
10 Mar 2022 11:36 - 10 Mar 2022 11:59 #236834
by Navanod
@andypugh thanks for helping me sort through this,
Reverse direction would be great for ridgid tapping:) I have only seen C89 on the cncforpc store but I would love to know alternatives as it may be easier for me to source in Germany. I can also build one if I knew of any schematics DIY options(i have an electronics lab here).
Yes the drive has step and direction input modes I can also interrace with the encoder but it is 2500ppr/10000per turn so thats way too much I am guessing if I dont have a 7i76E.
Only problem now is interfacing it with a cnc controller that I can actually get my hands on or perhaps figure this out with a less high resolution encoder on the spindle for feedback for now with a break out board of some kind. If I can figure out the last part I can more or less start to build everything.
cheers
cheers
Last edit: 10 Mar 2022 11:59 by Navanod.
Moderators: cncbasher
Time to create page: 0.120 seconds
