epoxy granite cnc lathe
- Masiwood123
- Topic Author
- Thank you received: 74
29 Aug 2022 14:20 - 29 Aug 2022 14:27 #250685
by Masiwood123
epoxy granite cnc lathe was created by Masiwood123
hello everybody
new project to present, cnc lathe 4th axis for both wood and metal. it is under construction , i did alu frame and put epoxy quartz sand mix to construction-plan is to make it run with mesa 7i96s i ordered. thank you for every future assistance ,I hope that I will not have many questions and that I will finish the project without major problems:) I will post the progress here weekly. greetings vladimir www.youtube.com/shorts/u4lkFV5wVno
Last edit: 29 Aug 2022 14:27 by Masiwood123.
- Thank you received: 5972
01 Sep 2022 10:25 #250913
Replied by tommylight on topic epoxy granite cnc lathe
That should help a lot with damping vibrations, although i would have used metal in this case, more space to fill and heavier, but more work mounting stuff to it.
Nice work, do post more pictures, we like looking at them.
The following user(s) said Thank You: Masiwood123
- Masiwood123
- Topic Author
01 Sep 2022 11:01 #250916
by Masiwood123
Replied by Masiwood123 on topic epoxy granite cnc lathe
thanks Tom old mate! I agree that metal is better, but I don't have that tool, I would have to carry the construction to leveling.. this turned out really hard and heavy. I will post more pictures due to the lack of free time, I am limited to a couple of bolts per day:)
QUESTION FOR THE EXPERTS.. this will primarily work with smaller pieces of wood, and generally I will use the main head as the A axis, now during the operation it should also be used as the S command (spindle) so that the processed part will be cut by a classic knife. The drive motor is ac servo 1500rpm (encoder 10k ppr which can be divided into smaller ones in the driver) the plan is to use the head on stepdir command for the A axis. My question is essentially that llinuxcnc can read one stepgen both as A (index) and as S (full rpm) command at the same time? I know Mach3 can do it.
- Masiwood123
- Topic Author
01 Sep 2022 11:03 #250917
by Masiwood123
01 Sep 2022 20:51 #250944
by Bari
Replied by Bari on topic epoxy granite cnc lathe
You're already half way done but you still might like to read
Principles of Rapid Machine Design
my.mech.utah.edu/~bamberg/research/Princ...Machine%20Design.pdf
The following user(s) said Thank You: tommylight, Masiwood123
- Masiwood123
- Topic Author
01 Sep 2022 21:20 #250946
by Masiwood123
Yes, mechanically, I'm almost halfway done and I already have the whole plan and a lot of axles that were removed from the factory machines and I'm looking to use them. anyway very good document, thanks a lot!
- Masiwood123
- Topic Author
03 Sep 2022 21:55 #251141
by Masiwood123
Little update today, 50%done.
- Masiwood123
- Topic Author
03 Sep 2022 21:57 - 03 Sep 2022 22:08 #251142
by Masiwood123
Last edit: 03 Sep 2022 22:08 by Masiwood123.
- Masiwood123
- Topic Author
10 Sep 2022 19:56 #251633
by Masiwood123
- Masiwood123
- Topic Author
10 Sep 2022 20:29 - 10 Sep 2022 20:31 #251637
by Masiwood123
Last edit: 10 Sep 2022 20:31 by Masiwood123.
Moderators: cncbasher
Time to create page: 0.298 seconds
