Single card solution for Hurco bmc 20 bmc 30 slv 40,
- smc.collins
- Thank you received: 109
07 Sep 2022 20:51 #251438
by smc.collins
Single card solution for Hurco bmc 20 bmc 30 slv 40, was created by smc.collins
lookin for the best single card option to control these machines.
Not terribly budget concious, just want things to work right out of the gate with minimal headache. Multicard setups aren't really something I am interested in, to much configuration headache
14 Sep 2022 12:54 #251895
Replied by andypugh on topic Single card solution for Hurco bmc 20 bmc 30 slv 40,
What are the servo drive interfaces? Presumably analogue voltage?
- Thank you received: 5966
14 Sep 2022 13:13 #251897
Yaskawa drives with Honda connectors, can not recall what type.
Spindle drive has also Orient, oriented and some other functionality.
All drives have a 0-3.3V output for load monitoring.
Replied by tommylight on topic Single card solution for Hurco bmc 20 bmc 30 slv 40,
Yes, 20 and 30 are the same in every way i could see.What are the servo drive interfaces? Presumably analogue voltage?
- smc.collins
16 Sep 2022 17:18 #252090
by smc.collins
Replied by smc.collins on topic Single card solution for Hurco bmc 20 bmc 30 slv 40,
the slv40 has electrokraft dc brush servo, yaskawa spindle, the bmc 20 and 30 are basically the same.
Moderators: cncbasher
Time to create page: 0.083 seconds
