Connecting quadrature encoder to spindle on Mesa 7i76e
- bird-dogman
25 Mar 2023 15:46 #267471
by bird-dogman
jim
- This is in preparation for rigid tapping.
- Encoder is a Chinese knock off 2500P/R 12~24V DC E6B2-CWZ5B PNP.
- Added the encoder to linuxcnc using pncconf
- Encoder only has connections OUTA, OUTB, OUTZ, COM and (+5v-24v)
- Field power is 24v
- Using TB3 encoder section of the Mesa 7i76e board. Ignoring differential pins.
- Pin 7 A+
- Pin 9 GND
- Pin 10 B+
- Pin 12 +5v
- Pin 13 Index+
- Do I change jumpers 10,11 and 13 to use single ended.
- Do I supply 5v from TB3 pins 2 and 4 or use field power at 24v.
jim
25 Mar 2023 17:11 #267477
Replied by PCW on topic Connecting quadrature encoder to spindle on Mesa 7i76e
Unfortunately that's not really a suitable encoder
Best is 5V differential (linedriver) interface
Next is 5V single ended (TTL)
12-24V NPN will work as the outputs are just open collector
with a ground reference so you end up with 5V signals when connected to
the 7I76E's encoder inputs with their 2K Ohm pullups to 5V
12-24V PNP is a sourcing output device with 12-24V outputs
To make this work with the 7I76E's 5V single ended pulled-up inputs
you would need a voltage divider on each pin with a low enough resistance
to swamp the built in 2K ohm pullups. Say for A:
Encoder A --> 1K Ohm --> 7I76E ENCA --> 330 Ohm --> GND
- bird-dogman
25 Mar 2023 18:01 #267485
by bird-dogman
Replied by bird-dogman on topic Connecting quadrature encoder to spindle on Mesa 7i76e
Thank you.
I just ordered 5V differential (linedriver) KOYO TRDA-20R1N2500VD from ebay. Seemed like a good deal.
I appreciate the help.
Jim
Jim
- bird-dogman
31 Mar 2023 19:00 #267977
by bird-dogman
Encoder KOYO TRDA-20R1N2500VD arrived from ebay. New open box unit.
Changed jumpers W10,W11 and W13 to the differential position. Wired per Mesa 7i76e document for TB3 encoder section.
Spun the encoder shaft by hand see nothing that indicates its working
james@LinuxCnc:~$ halcmd show pin hm2_7i76e.0.encoder
Component Pins:
Owner Type Dir Value Name
26 s32 OUT 0 hm2_7i76e.0.encoder.00.count
26 s32 OUT 0 hm2_7i76e.0.encoder.00.count-latched
26 bit I/O FALSE hm2_7i76e.0.encoder.00.index-enable <=> spindle-index-enable
26 bit OUT TRUE hm2_7i76e.0.encoder.00.input-a
26 bit OUT TRUE hm2_7i76e.0.encoder.00.input-b
26 bit OUT FALSE hm2_7i76e.0.encoder.00.input-index
26 bit IN FALSE hm2_7i76e.0.encoder.00.latch-enable
26 bit IN FALSE hm2_7i76e.0.encoder.00.latch-polarity
26 float OUT 0 hm2_7i76e.0.encoder.00.position ==> spindle-revs
26 float OUT 0 hm2_7i76e.0.encoder.00.position-latched
26 bit OUT FALSE hm2_7i76e.0.encoder.00.quad-error
26 bit IN FALSE hm2_7i76e.0.encoder.00.quad-error-enable
26 s32 OUT 0 hm2_7i76e.0.encoder.00.rawcounts
26 s32 OUT 0 hm2_7i76e.0.encoder.00.rawlatch
26 bit IN FALSE hm2_7i76e.0.encoder.00.reset
26 float OUT 0 hm2_7i76e.0.encoder.00.velocity ==> spindle-vel-fb-rps
26 float OUT 0 hm2_7i76e.0.encoder.00.velocity-rpm ==> spindle-vel-fb-rpm
26 bit IN FALSE hm2_7i76e.0.encoder.hires-timestamp
26 u32 IN 0x017D7840 hm2_7i76e.0.encoder.sample-frequency
26 s32 IN -1 hm2_7i76e.0.encoder.timer-number
Tried setting signal spindle-index-enabale still nothing. I expected to see at least hm2_7i76e.0.encoder.00.count to go up.
Any debug suggestions.
jim
Component Pins:
jim
31 Mar 2023 21:05 - 31 Mar 2023 21:11 #267986
I would measure the differential A and B inputs (measure between ENCA- and ENCA+
and ENCB- annd ENCB+)
By moving the spindle you should be able to get + and - differential voltages on both A and B
If you get any differential voltages less than absolute 2V (any voltage in the range from -1.99V to 1.99V)
there is likely a wiring error.
Last edit: 31 Mar 2023 21:11 by PCW.
- bird-dogman
01 Apr 2023 12:38 #268017
by bird-dogman
I was rushing.
There was a problem with the 5v ferrule crimp. Seems to be working as it should now.
I have to machine a part to mount the encoder next, then try a G33.1.
thank you
jim
thank you
jim
05 Apr 2023 16:18 #268342
by Tarja
Replied by Tarja on topic Connecting quadrature encoder to spindle on Mesa 7i76e
Hi, I am in a very similar situation with single ended pnp 24V inductive encoder.
@PCW do you have any hint where to find or how to build such a voltage divider
I mean in theory I know how but is there something special to know for this specific case
05 Apr 2023 16:47 #268343
I would use a 2 resistor pair per A/B/IDX:
24V PNP encoder signal --> 1K 1W --> 5V encoder input --> 240 Ohm 1/4W --> GND
05 Apr 2023 19:25 #268349
by Tarja
I will try this, thx
06 Apr 2023 05:02 #268381
by Tarja
I found a 240ohm 600mW should work.
Moderators: cncbasher
