6040 7i76 Conversion
- spacestate1
- Thank you received: 7
08 Aug 2023 02:43 #277306
by spacestate1
Replied by spacestate1 on topic 6040 7i76 Conversion
ok interestingly enough if I wire it like this
VFD FWD -> PIN2
VFD 5vin -> PIN2
VFD GND -> PIN1
VFD 5vout -> PIN3
I can control the spindle speed from Linuxcnc
M3 S10000 gets it to about half speed (According the the VFD LDC)
Is this expected/ Safe ?
VFD FWD -> PIN2
VFD 5vin -> PIN2
VFD GND -> PIN1
VFD 5vout -> PIN3
08 Aug 2023 02:48 - 08 Aug 2023 02:52 #277307
Replied by PCW on topic 6040 7i76 Conversion
No, you should not connect a digital input (FWD for example)
to the analog output (TB4 pin 2)
FWD should connect to ENA+ and ENA- should connect
to VFD GND.
This is necessary so LinuxCNC can enable/disable the
drive
to VFD GND.
drive
Last edit: 08 Aug 2023 02:52 by PCW.
- spacestate1
08 Aug 2023 03:10 #277309
by spacestate1
I'm kind of at a loss at this point, maybe the VFS is mislabeled for a setting on it is not correct.
08 Aug 2023 03:16 - 08 Aug 2023 03:17 #277310
With VFD FWD connected to
ENA+ and and VFD GND connected to ENA-,
what voltage do you read on VFD FWD
(relative to VFD GND)
when the spindle is enabled in LinuxCNC?
Last edit: 08 Aug 2023 03:17 by PCW.
- spacestate1
08 Aug 2023 11:54 #277324
by spacestate1
when enabled and spinning .614 v
when off and still 11.57v
- spacestate1
09 Aug 2023 01:00 #277385
by spacestate1
ALso does anyone know of a cheaper VFD for a 1.5kw spindle that might work better with the 7i76 card/Linuxcnc ?
- spacestate1
13 Aug 2023 12:36 #277820
by spacestate1
Just to complete this discussion, I bought a Huanyang VFD hooked it up with a guide here.
www.diycncdesign.com/linuxcnc-2.8-huanyang-vfd.html
Works, but not sure what was wrong with the old VFD, it works in manual mode fine. But the Huanyang is higher quality for sure.
Moderators: cncbasher
Time to create page: 0.145 seconds
