bridgeport series 1 cnc linuxcnc help
16 May 2023 00:51 #271432
by steevgg
bridgeport series 1 cnc linuxcnc help was created by steevgg
i would like some help in converting this to linuxcnc
what would i need, to be able to convert it ? can i use old electroics and put in a new board for linuxcnc which one is recommened and thats in stock
16 May 2023 12:49 #271455
Replied by andypugh on topic bridgeport series 1 cnc linuxcnc help
It looks like DC servos, probably +/-10V control.
Do you have a PC with PCI or PCIe ? Or would you prefer to connect via Ethernet?
The 7i97 would be a good choice, except that they are out of stock.
So perhaps
store.mesanet.com/index.php?route=produc...83_85&product_id=379
and
store.mesanet.com/index.php?route=produc...id=120&search=analog
There are also options using the parallel port (as a communications bus, not bit-bashing)
pico-systems.com/PPMC.html
Or
store.mesanet.com/index.php?route=produc...ct_id=70&search=7i43
and
store.mesanet.com/index.php?route=produc...=83_86&product_id=74
So perhaps
and
Or
and
- smc.collins
- Thank you received: 109
16 May 2023 19:17 - 16 May 2023 20:06 #271464
by smc.collins
Replied by smc.collins on topic bridgeport series 1 cnc linuxcnc help
does the machine currently operate ???
it matters for figuring things out. a friend of mine has the same machine, but he had anilam controls, we're replacing the servos etc, his motors are really worn.
Last edit: 16 May 2023 20:06 by smc.collins.
16 May 2023 22:28 #271480
by steevgg
Replied by steevgg on topic bridgeport series 1 cnc linuxcnc help
yes it ran before i picked it up mine has the contraves dc servos
i would eventually want to upgrade the nc400 drives to something more modern as well but for right now just want to get it running on linuxcnc
16 May 2023 22:32 #271482
by steevgg
yeah i have a PC is there a difference in using Ethernet over pcie
yes mostly everything is out of stock
i did find a 5i25 on ebay would that work ?
- Thank you received: 5933
16 May 2023 22:44 #271484
Replied by tommylight on topic bridgeport series 1 cnc linuxcnc help
As far as i can gather, Mesa 7i96S and Mesa 7i77 are available most of the time, so maybe go for that?
It is the most versatile combo for sure, 5 stepgens, 1 spindle, 6 of +-10V PWM one of those is for spindle or servo, plenty of IO, plenty of SSerial for expansions just in case, etc etc.
The difference in price should be 50 to 80$ more, not sure as i have not looked at those in a while.
- smc.collins
17 May 2023 02:00 - 17 May 2023 02:01 #271494
by smc.collins
kb electronics has some affordable dc drives, as does pico systems. if you watch out, you can occasionally pickup glentek drives in ebay for a song, the pwm brush dc drives are superb
Last edit: 17 May 2023 02:01 by smc.collins.
17 May 2023 15:24 - 17 May 2023 15:25 #271544
No, they all work almost exactly the same. (I seem to recall that the actual best performance FPGA card is the EPP-interfaced 7i43).
But they all have lots more capability than is needed for LinuxCNC applications.
In Cyprus? I am puzzled by those (ie, why he has so many). 5i25 works great (you would pair it with a 7i77) but you need a full-size PCI slot.i did find a 5i25 on ebay would that work ?
Last edit: 17 May 2023 15:25 by andypugh.
17 May 2023 15:48 #271545
Now even more puzzled, as it says "Vilnius, Cyprus" (Vilnius is not in Cyprus) but it is a UK seller.
In Cyprus?i did find a 5i25 on ebay would that work ?
17 May 2023 21:45 #271570
by steevgg
yeah i wondered too why he has so many unless he works for them lol
Moderators: cncbasher
