The problem of axis alignments X/Y
23 Sep 2023 04:33 #281427
by Ermolin
The problem of axis alignments X/Y was created by Ermolin
With circular interpolations, stepper motors knock, and lose speed. Is it possible in Linux cnc to split circular interpolation into arcs or straight lines for smooth running?
23 Sep 2023 09:37 #281451
Replied by andypugh on topic The problem of axis alignments X/Y
What does your G-code look like?
It is possible that you have set the axis accelerations too high, if it is causing problems for the motors.
Have you read this section of the docs?
linuxcnc.org/docs/stable/html/user/user-...#_trajectory_control
Moderators: cncbasher
