retrofitting a New CNC router (Osai Open XS control to Linuxcnc)
03 Nov 2023 10:22 #284430
Replied by andypugh on topic retrofitting a New CNC router (Osai Open XS control to Linuxcnc)
Looking throigh the INI I see that JOINT1 has HOME_USE_INDEX = YES whereas JOINT2 has HOME_USE_INDEX = no
The rest of the config looks like both should be set to "YES"
03 Nov 2023 15:44 #284466
by lunada
Replied by lunada on topic retrofitting a New CNC router (Osai Open XS control to Linuxcnc)
yea i just did that so i could actually home it. It was set to yes when it was doing what i described. I meant to change it back before posting, but forgot, sorry.Looking throigh the INI I see that JOINT1 has HOME_USE_INDEX = YES whereas JOINT2 has HOME_USE_INDEX = no
03 Nov 2023 15:49 #284467
by lunada
ok i will check. that may be likely due to the fact that the encoder scale is very high. good call. Since the encoder signal comes from the drives and not the actual encoder, i may be able to scale it down if it is anything like my other machine.Los of control at higher speeds may mean that you have exceeded the count rate of
the encoders with the current sample rate/filter settings. A simple check would be to see if
setting the encoder filter off increases the speed before runaway.
03 Nov 2023 16:26 #284473
Replied by PCW on topic retrofitting a New CNC router (Osai Open XS control to Linuxcnc)
You can speed the 7I95T encoder counting up quite a bit if needed
but with the default sample rate and filter settings, its pretty slow
03 Nov 2023 16:33 #284474
by lunada
The counts per second for each axis are as follows at max velocity.
Z 3,329,228.8
X 3,986,980.99
Y1 3,986,980.99
Y2 3,986,980.99
I saw the sample rate in the manual, is that per channel or total?
So i just did some math, and i hope i'm not screwed here.You can speed the 7I95T encoder counting up quite a bit if needed
Z 3,329,228.8
X 3,986,980.99
Y1 3,986,980.99
Y2 3,986,980.99
03 Nov 2023 16:50 #284478
The sample rate applies to all channels (and defaults to 25 MHz)
With the digital filter on, 15 samples are required to detect a signal
so about 600ns per edge and 1.66 Mhz max count rate. With the filter off,
3 samples are required to detect an input so ~120 ns per edge or about
8 MHz maximum count rate. Because of quadrature distortion (the quadrature
from the drive is not exactly 50% duty cycle) you need a lot of margin.
03 Nov 2023 17:09 #284483
by lunada
So if i'm understanding this right, i should be fine with filtering off?The sample rate applies to all channels (and defaults to 25 MHz)
04 Nov 2023 17:16 #284549
by lunada
so i think i fixed the overrun issue by changing the encoder output from the servo drives to a smaller number. However, i am still having the homing issue
Moderators: cncbasher
Time to create page: 0.162 seconds
