Memory Dump
22 Oct 2023 20:10 #283532
by Cyber
Memory Dump was created by Cyber
Hi All,
How can I dump Mesa's card memory content ?
22 Oct 2023 22:02 #283539
by cornholio
Replied by cornholio on topic Memory Dump
If you are talking about the bit file, you really don't need to as the bit files are all available, all source code is available if you want to know whats going on source code wise.
Otherwise you'll have to get into boundary scanning.
22 Oct 2023 23:34 #283545
Replied by andypugh on topic Memory Dump
It looks like the mesaflash command "backuo-flash" will do what you want:
manpages.debian.org/testing/mesaflash/mesaflash.1.en.html
- Thank you received: 5946
23 Oct 2023 00:09 #283546
Replied by tommylight on topic Memory Dump
the above should be
"backup-flash"
"backup-flash"
The following user(s) said Thank You: Cyber
Moderators: cncbasher
Time to create page: 0.075 seconds
