clausing kondia retrofit
20 Nov 2023 20:00 #286092
by btvpimill
clausing kondia retrofit was created by btvpimill
I have a machine to retrofit. Seems pretty straight forward (famous last words)
Drives are good, spindle is good, control is shot.
drives are some type of analog input (0-10, +-5,something)
encoder feedback is all differatial (+a-a, +b-b, +z-z)
lots of I/O
I have on hand a 5i25 and a 7i77. Will this get me there to talk to 4 analog drives and read 4 encoders? will it leave me with lots of I/O?
need to get the tool changer working as well.
If I need more/other boards I am happy to buy them.
In my dream world this would be connect the signals and everything works after proper configuration. meaning the hardware is not the issue.8
lots of I/O
20 Nov 2023 20:17 #286096
by btvpimill
Replied by btvpimill on topic clausing kondia retrofit
PS, I am VERY excited to have a full size mill running on LinuxCNC. IMHO it is the best control out here.
20 Nov 2023 20:52 #286100
by btvpimill
Update, I believe I need +-10Vdc to control the drives.
- Thank you received: 5944
20 Nov 2023 22:13 #286105
Replied by tommylight on topic clausing kondia retrofit
Yes, yes, and yes.
Mesa 7i77 has 6 outputs that can do +-10V or anything in between, and can read 6 encoders as is.
Here is a nice start, no skimping
www.forum.linuxcnc.org/10-advanced-confi...ning-detailed-how-to
21 Nov 2023 00:30 #286123
Replied by andypugh on topic clausing kondia retrofit
If you need more IO then the 7i77 can add a single smart-serial card, and then a 7i74 on the second DB25 headers can add another 8. That's a couple of hundred IO lines. Which should be enough.
21 Nov 2023 09:46 #286154
by btvpimill
First time for everything I suppose! It sounds like I have all I need to get this started (except for time of course)
It will take some time but I will report back anything relevant and of course I will ask all the silliest questions.
Thanks for the link Tommy, that will be VERY helpful indeed as well as the referenced tuning guides by JT and Andy when I find them.
29 Jan 2024 08:08 #291877
Spammer booted.
Moderators: cncbasher
