LinuxCNC compatible VFD's
14 Jan 2024 12:56 #290635
by tom_no
LinuxCNC compatible VFD's was created by tom_no
How do I go about finding LinuxCNC compatible VFD's when having to replace my current?
Looking for a 7.5 kW drive with serial communications support.
14 Jan 2024 13:38 #290637
by Calysto
Replied by Calysto on topic LinuxCNC compatible VFD's
In the linuxcnc
manual
, under Hardware Drivers, you will find the standard drivers. But with mb2hal, VFDMOD, Classic Ladder, etc.. you can communicate with every VFD that uses standard modbus.
15 Jan 2024 09:59 #290747
Replied by andypugh on topic LinuxCNC compatible VFD's
Just to insert a mention of mesa_modbus, which should allow realtime Modbus control via the Mesa card UARTs.
The manpage for this also lists the dedicated drivers and other modbus tools:
linuxcnc.org/docs/stable/html/drivers/mesa_modbus.html
15 Jan 2024 20:30 #290794
by tom_no
Replied by tom_no on topic LinuxCNC compatible VFD's
I didn't think it was possible to use the serial connection on the MESA board for modbus; quite sure I've seen comments about it seaching the forum. New features enabled by PCW?
To be spesific; can I use the RS-422 serial port on the MESA 7i77 for modbus communication with a VFD supporting RS-485 modbus? No need for USB dongle?
I added this to my shopping basket yesterday in frustration over the old one;
no.mouser.com/ProductDetail/Delta-Electr...=NO¤cyCode=NOK
15 Jan 2024 22:01 - 15 Jan 2024 22:01 #290806
Probably not, but PCW would know for sure. It depends if that RS422 port has a tx-enable pin. Only one of those on the 7i74 is available because of this limitation, and the 7i77 is also a 25-pin card, so probably runs into the same pin-count limitation.To be spesific; can I use the RS-422 serial port on the MESA 7i77 for modbus communication with a VFD supporting RS-485 modbus? No need for USB dongle?
Last edit: 15 Jan 2024 22:01 by andypugh.
15 Jan 2024 22:08 #290808
To go into this further, the 7i74 pinout on page
4 here
has a single /TXEN7 pin. The
7i44
has one for every channel.
Looking at the manual for the 7i77 it looks like SmartSerial Channel2 does have TXEN pin, so there is a fair chance that it can be made to work, if SS2 is the expansion channel.
It would need a custom firmware with a UART on that channel instead of a smart-serial module.
Moderators: cncbasher
Time to create page: 0.130 seconds
