The Converter shows (inh), how could it be fixed?
16 Feb 2024 13:45 #293508
by anna
The Converter shows (inh), how could it be fixed? was created by anna
Hi all, after I connected all the pins to the converter and changed its value to suit the system. it shows me this message on his screen( inh) which means it’s locked. is there anyway to solve this problem? I would appreciate any help:)
16 Feb 2024 13:54 #293509
by Mecanix
Replied by Mecanix on topic The Converter shows (inh), how could it be fixed?
Please include a detailed schematic of the wiring, the model/make of the unit, hal configurations, firmware revision, linuxcnc version. And/or anything else you'd think could help yourself in getting support from a clueless community!
What's a converter?
What's a converter?
16 Feb 2024 14:13 #293510
Replied by Aciera on topic The Converter shows (inh), how could it be fixed?
usually if a VFD shows 'inh' it means it has not been enabled. What signals it expects to be enabled will depend on the parameter settings in the VFD itself so you would indeed need to provide us with a manual of the device and how you have connected it's inputs.
Moderators: cncbasher
Time to create page: 0.875 seconds
