compumill 4000 retrofit
06 Jan 2011 18:52 #6483 by dewey525
Replied by dewey525 on topic Re:compumill 4000 retrofit
Total cost we will have invested in the upgrade is right at $ 1400.00 for now. Thats the mesa configuration with a new pc mini atx MB and spindle VFD. The price thats not listed is the loss of production and the time put into the repairs.
Dynapath parts are way too high for their age on ebay. after dealing parts and smarts we decided they would be the only people we would trust to buy parts from for the dynapath, but they are just as if not more expensive. Their experience with the controllers is invaluable for guaranteed repairs and replacements.The processor itself is worth more than its weight in gold as there is no suitable replacement for it. That was the deciding factor for us to deal with an immediate upgrade.
07 Jan 2011 05:41 #6501 by will911
Replied by will911 on topic Re:compumill 4000 retrofit
The mini atx looks like a p.c. motherboard, what are you going to do with that?
I take it that your going to keep the power supply, D.C. motors and servos right?
I have no idea how your going to use this P.C motherboard to run your machine.
Details please?
08 Jan 2011 06:47 #6524 by dewey525
The mini ITX is a pc motherboard. These are designed I think mainly for small desktop pc's. They have low latency, but thats another issue which I have not studied ( there are 2 of us working this project my part is the physical integration of the equipment to hardware chosen by myself and my partner ) The true heart of the hardware system we are working on is the PCI interface card 5I20 which bigjohnT has suggested for use which the daughter cards interface with. The 7I33 and the 2 - 7I37ta cards. All this spells out to 4 axis motion controller running existing baldor servo drives and the with isolated I/O's that are necessary for safe machine automation. We have chosen the mesa systems because of the PCI interface.
We will not be using the dynapath power supply for the upgrade as it is very expensive to replace and well its with the dynapath control which we returned to the machine seller. There are lots of manufacturers of power supplies that are way cheaper to buy and replace than the deltron on that dynapath which is bad. This power supply has a few pots on it which have been adjusted to lower resistance of the outputs to increase the 5v output ( actually only putting out right at 4v if the others were in spec) which was getting weak as it aged. Thats why the 24v and +-15v are so far out of whack. We will be keeping the existing baldor power supply , servo drives, as well as the existing servos and encoders.
The only thing I will replace of the existing system are the omron relays on the PIC interface board that are 24v with the same type but 12v., which allows us to use a more generic power supply.
All in all its everything the dynapath is, just a bit more advanced, as we can add features such as the spindle VFD which the dynapath cant handle without modifying its software and probably hardware as well as limited memory. We are setting up this machine to run some complex 3d profiling which the dynapath can do by drip feeding, but as we have yet to hear back about our control Im worried they just are not going to return it to us as its problems and replacement parts exceed the price paid to the merchant for the entire machine. At this point we just want the dynapath back working so we can test all mechanical systems. If I have to pull everything loose from the controls and out of the panduit just to test Im not putting a 23 yr old controller back on it. Plus If we find the spindle is shot like on the first machine we purchased its being loaded back on a truck and sent back to the merchant. So I do not want to modify it or really tear into it yet.
I first Installed EMC2 5 months ago on a linux pc and have been working my way through the manuals since. We were going to build a small CNC engraver first to get the hang of it, but thats now on hold even though we need it as our parts must be serial numbered and logged for tracking by the ATF. Id rather be producing parts, but thats not going to happen anytime soon.
I can tell you that this is not as simple as just buying a new control system and connecting it all together, but you will get a better understanding of a machine and how it interfaces with its control, and software. The one thing Ive found is there is better support for EMC2 than a lot of control software because its open source. Its an entire community interacting and working together.
08 Jan 2011 13:37 #6530 by BigJohnT
Replied by BigJohnT on topic Re:compumill 4000 retrofit
That is the truth, Rob H from England stayed up real late many nights trying to help me get my Hardinge CHNC original controls up and running via the IRC. Once I made the decision that the only way was to convert to EMC2 the software choice was simple... then the research for the hardware. I screwed up by trying to get a few older computer motherboards to work and wasted a couple of weeks playing with that. All in all I'm glad that I ended up with a good CNC lathe powered by EMC2. I wished I had known about the D510MO at the time as that would have made the PC install much easier.
08 Jan 2011 14:36 #6540 by will911
By the way you wrote that, it sounds like you won't need to drip feed, am I correct on that?
Also if you completely replace the controller and use software only "which is what I would rather do" Then you will also lose to tool cal soft key and many other functions. So I'm thinking that you must have a program to install on a hard drive for that new P.C. board. The other thing is why would you want to use a mother board that is much weaker than other boards that are out there. I would use the best mother board I could. The mother boards from the HP XW8600 are the fastest ones ever made "as far as I know". I do know that they were the fastest in the world not so long ago.
This sounds like a cool project and a very good learning experience.
08 Jan 2011 16:33 - 08 Jan 2011 16:57 #6547 by PCW
Replied by PCW on topic Re:compumill 4000 retrofit
EMC2: www.linuxcnc.org/content/view/11/10/lang,english/ is the CNC control software being discussed here
Raw CPU performance is less important to EMC2 than latency (how quickly the CPU responds to real time requests)
Many very fast systems have poor latency.
the D510 Mini ITX motherboards have known good latency and adequate performance, which is why they are suggested as EMC2 platforms.
Last edit: 08 Jan 2011 16:57 by PCW. Reason: clarify
08 Jan 2011 19:46 #6553 by andypugh
Replied by andypugh on topic Re:compumill 4000 retrofit
It's only software and electronics, it should be perfectly possible to add such things back in to the EMC2 config.
As it happens, those little, cheap, Atom boards have about the best latency that we have seen. CNC is not at all demanding of raw computing power, they could do it in the 60s and the rate at which you can machine metal has probably no more than doubled since then. What matters most is that when EMC2 wants some CPU time it gets it exactly then. The D510MO has a dither of 5000nS or so on the realtime threads. That's about as good as it gets in a PC board. Some high-performance boards can be 300,000 or more. They are still very fast boards, but they do too much clever stuff that gets in the way of our very basic and simple requirements.
08 Jan 2011 23:52 #6557 by will911
Thanks for that link, Looks very interesting.
09 Jan 2011 00:07 #6558 by will911
Not many people know about the HP XW8600, Gamers spend all kinds of money on what I consider a poor performing machine. The last gamer I talked too was just overwhelmed when I told him about the XW8600, He is a computer expert who had no idea what they were. The HP XW8600 supports
128 GIGs of RAM Memory. He swore I must be wrong on that and thought I was confused with how many GIGs the hard drive would hold. He was wrong.
Anyways the board you guys are talking about is probably good enough.
I guess the real question is how do you connect all the wires that went to the controller to the new P.C.???
09 Jan 2011 00:48 #6559 by andypugh
Maxxed-out a Mesa 5i22 full of 7i64 boards has 1536 pins of GPIO. Is that enough :-)
Typically you wouldn't do it that way, the 72 IO pins on the 5i23 without all the peripheral cards is plenty.
(Other options exist, from Pico, Motenc, Pluto…..)
Moderators: cncbasher
Time to create page: 0.401 seconds
