sherline machine
10 Sep 2009 09:30 - 10 Sep 2009 09:31 #806
by vincent
sherline machine was created by vincent
anybody using sherline CNC?? pls help, i need to install a fly cutter, how to remove my chuck first and the install the cutter??
Last edit: 10 Sep 2009 09:31 by vincent.
13 Nov 2009 15:46 #1117
by piasdom
Replied by piasdom on topic Re:sherline machine
I have the sherline 5400 cnc mill.
the flycutter should have come with bolt that goes thru the top of the spindle and screws to the cutter.
the bolt is a 1/4" -20 X 5" long.
hope this helps.
hope this helps.
13 Nov 2009 15:49 #1118
by piasdom
forgot about the chuck. it has a bolt in it also, just unscrew it.
Moderators: cncbasher
Time to create page: 0.349 seconds
