Wire cutting foam
20 Sep 2009 23:23 #851
by leecnc
Wire cutting foam was created by leecnc
Need help locating info on cutting foam with hot wire using EMC2 software on an 2 axis machine. Looked but could not find.........LEE
21 Sep 2009 12:01 #854
by BigJohnT
Replied by BigJohnT on topic Re:Wire cutting foam
29 Jan 2010 07:01 #1679
by eina
Replied by eina on topic Re:Wire cutting foam
I've build a 4 axis hotwire cutter ( cheap but working) and is currently using winxp and foamworks. could I switch over to emc? and how. I need the 4 axis to cut wings. I would also like to late convert the machine for routing as well, since I've got 2 of the 3 axis for that already.
- step4linux
- Thank you received: 5
29 Jan 2010 07:15 #1681
by step4linux
Replied by step4linux on topic Re:Wire cutting foam
I've
built
a foam cutter with a special mechanics, which needs kinematic transformation.
see here .
Unfortunately the doc is in german language .
If you have a traditional linear axis mechanic, the hal and ini may work for you as well, just don't use the kinematic transformer.
Which SW are you going to use to create the nc files ?
rgds Gerd
see here .
rgds Gerd
Moderators: cncbasher
