Bridgeport Upgrade
08 Apr 2011 01:59 #8690 by Gensor
Bridgeport Upgrade was created by Gensor
Hello,
I am curious what the cost and mesa card differences would be between the following:
1) Bridgeport series 1 or 2 850-1350 oz-in steppers upgraded to AC? DC? brush(less?) servos and Mesa cards. Please provide the best off-the-shelf solution, and an ebay equivalent for the servo/encoder. Suggested powersupply solution/volts/amps?
2) Bridgeport series 1 or 2 DC brush servo system upgraded to Mesa cards
3) Bridgeport series 1 or 2 AC servo system upgraded to Mesa cards
Keywords: Bridgeport Boss, Bridgeport Interact
Old Mesa Card for Reference and is a good example of end product I am trying to achieve, joysticks included in I/O:
machineability.com/Bridgeport_series_II.html
Please help connect the dots. Thanks!
11 Apr 2011 11:51 - 11 Apr 2011 11:52 #8753 by andypugh
Replied by andypugh on topic Re:Bridgeport Upgrade
The stepper motor versions do actually work. if you found one at the right price you could leave it stepper. (And probably drive it with nothing more than a parallel port). I guess this would be the base price.
For a complete bolt-on system you might want to look at Pico Systems: pico-systems.com/oscrc4/catalog/index.php?cPath=3
Otherwise, I would be tempted to see what you can find on eBay at a good price and choose the rest of the system to suit.
As an example I am currently configuring a system around some Lenze servos, they need 7.5A at a max of 350V, so I am making a simple rectifier-and-cap PSU, Mesa 5i23 and Mesa 8i20 drive cards. It would be perfectly possible to run the same system with a 7i43 too.
That would suit a 5i20/5i23/7i43 and 2x7i29 (dual 2kW H-bridge)
That would depend on the spec of the servos, but the 8i20 is a possibility (but that is not actually supported by the current production EMC2 release)
Last edit: 11 Apr 2011 11:52 by andypugh.
12 Apr 2011 02:23 #8786 by Gensor
Replied by Gensor on topic Re:Bridgeport Upgrade
Thanks Andy! And more questions..
1) What software are you using with your 8i20 setup?
2) When do you think EMCx will support 8i20? It appears this card has been out for over two years. If there was support, what percent of AC servo motors with similar volt/amp requirement be supported by this servo amp?
This must be a title typo
12 Apr 2011 09:52 #8792 by andypugh
EMC2 version 2.6 (development version).
Support will be in version 2.5 which is probably a few weeks from release. You can download and compile it now, though, if you want.
All of them. There is a HAL component that can take the feedback from any motor and convert it to the drive signals for any drive supported by EMC2.
There is the beginnings of a Wiki page on the subject here, but I got distracted: wiki.linuxcnc.org/cgi-bin/emcinfo.pl?BLDC
Moderators: cncbasher
Time to create page: 0.403 seconds
