Start here for building a Mini-Mill
04 Oct 2009 18:29 #922
by sao
Start here for building a Mini-Mill was created by sao
I'm wanting to build a mini-mill similar to what Ernie is doing (me thinks), but I'm not sure where to start, as a gazillion others it seems. I was thinking of purchasing a kit, but I would like to build if at possible.
buildyourcnc.com/default.aspx
I was thinking that converting these plans to my own personal needs might work. First off, I don't want wood, some type of metal or plastic machine would be preferable. I'll be working with PCBs.
So maybe a listing of kits would be nice, as would helpful information on what needs to be purchased to convert the above mentioned machine to a mini-mill. Or maybe just a listing of parts needed for a mini-mill, though, instructions for where these parts go would be nice
Are there other considerations that a beginner should consider not listed above?
Hope this will be beneficial to me and others who arrive here with similar questions, so thank you in advance
08 Oct 2009 03:20 #930
by BMG
Replied by BMG on topic Re:Start here for building a Mini-Mill
There are alot of options for building a CNC.
Based on your link, you appear to be looking for a wood router based machine. The buildyourowncnc is quite pricey at 1200 but I did not look into it too much.
There are several other options like the Jgro1 build and then use to build a Jgro2 - see cnczone.com for forums extensively discussing this route. If your into the machine build (and not immediately looking to make other parts) then this can be a very rewarding path. I personally burchased a Lionclaw kit 2 years ago. It presently sells for about $400 and is based on a rollerskate bearing design. It works for me.
There are also other designs on instructables.com that are beginner and easily built with few tools. It might be a good way to learn the mechanics of a machine before delving into a more advanced project.
HTH's.
Brian
HTH's.
Brian
- therouterlady
28 Oct 2009 06:06 - 30 Oct 2009 06:11 #1056
by therouterlady
Replied by therouterlady on topic Re:Start here for building a Mini-Mill
Great job, i also want to see when you finished building your machine.
Last edit: 30 Oct 2009 06:11 by alex_joni. Reason: please don't use the general forum for advertising
Moderators: cncbasher
Time to create page: 0.234 seconds
