DraftSight from Dassault Systems for linux
25 Nov 2011 14:24 #15093
by BigJohnT
Replied by BigJohnT on topic Re:DraftSight from Dassault Systems for linux
Oh, I thought he was doing splines like a shaft or something...
03 Dec 2011 15:42 #15325
by dab77
Replied by dab77 on topic Re:DraftSight from Dassault Systems for linux
Hi both, thank you for interest!
if i only know how to program my self a script or an excell sheet for my needs, sure i'll spend a lot of time on it!!
re-studying what Mr Newton said i think is not enough, since i'm not making flying only balls! so i need every kind of trajectories in the air.
03 Dec 2011 15:48 #15326
by dab77
...but...maybe what you suggest can be useful when i need to program little shows, made of a few movements..
i think i'll start with a very simple sheet to turn into gcode lines..then i'll turn into curves.
i have to figure out how to say, for example a line passing thru 3 3d points and choose a value for example to take a point every 5cm..
ok, thank you, and suggestions are always welcome!
19 Apr 2012 01:34 #19366
by yello
Replied by yello on topic Re:DraftSight from Dassault Systems for linux
Sorry for adding to this old topic....
Can draftSight be installed in 8.04 ?
I get a range of errors. Or shall I just stick to QCAD? I like the idea having the same software on Linux and on WinXp.
06 Mar 2013 22:27 #30972
by FanParts
Replied by FanParts on topic DraftSight from Dassault Systems for linux
If you need 2D drawings for draftsight, you can download for free in this CAD library: www.tracepartsonline.net/ws/draftsight
Moderators: Skullworks
