dxf2gcode + EMC2 problem with G41/G42
09 Sep 2011 11:59 #13063
by dzarek
dxf2gcode + EMC2 problem with G41/G42 was created by dzarek
I loading drawing, I set the tool diameter, the radius of the entry as half of tool diameter, I set the direction and cutting direction. I generates code for the machine.
I open the EMC, loading the machine code, I set the tool.
EMC unfortunately does not want to reload the entire drawing. At the sharp angles of the program can not handle.
How do I make EMC wanted to round off such places?
Maybe I have something set incorrectly in dxf2gcode?
Jarek
Jarek
09 Sep 2011 18:23 #13071
by BigJohnT
Replied by BigJohnT on topic Re:dxf2gcode + EMC2 problem with G41/G42
Which G61/64 path control mode are you using?
www.linuxcnc.org/docview/html/common_User_Concepts.html
www.linuxcnc.org/docview/html/gcode_main...#sub:G61,-G61.1,-G64:
14 Sep 2011 09:49 #13194
by dzarek
Replied by dzarek on topic Re:dxf2gcode + EMC2 problem with G41/G42
Welcome
I tried to use these commands, but do not give a good result.
If you have some time, you can check the settings for this file
dl.dropbox.com/u/30217803/motyl.ngc
Tool diameter 1.1mm
Thank you
Tool diameter 1.1mm
Thank you
14 Sep 2011 11:12 #13197
by BigJohnT
What exactly have you tried with those commands?
14 Sep 2011 11:19 #13198
by dzarek
G64 and G64 with different P ang Q
14 Sep 2011 11:31 #13199
by BigJohnT
Did the result of using G64Pn not fall within the setting you used?
Can you try and explain your question better?
Can you quantify what a "good result" is?
Moderators: Skullworks
Time to create page: 0.349 seconds
