outher file formats
27 Nov 2011 23:12 #15147
by ezboy
outher file formats was created by ezboy
is there a way to get emc2 too see a .plt file,
or aney outher file than a .ngc?
27 Nov 2011 23:49 #15149
by BigJohnT
Replied by BigJohnT on topic Re:outher file formats
If it contains EMC2 compatible g-code you can just add the extension to the [DISPLAY] section of the ini file as shown in the Integrators Manual.
28 Nov 2011 21:56 #15172
by ezboy
Replied by ezboy on topic Re:outher file formats
can you give me a little more help?
i ran a search for ini in the manual with no luck.
please tel me what im doing wronge.
i know nothing about linux.
28 Nov 2011 22:05 #15173
by BigJohnT
First does the file contain EMC compatible g-code? Just rename one to .ngc and see if it will open in EMC.
The ini info is in the Integrators Manual.
28 Nov 2011 22:16 #15174
by ezboy
where can i find{ Integrators Manual}?
28 Nov 2011 23:29 #15176
Replied by andypugh on topic Re:outher file formats
ezboy wrote:
It's not a Linux thing.
You probably need the info here (it is in the manual too)
www.linuxcnc.org/docview/html/config_ini_config.html
29 Nov 2011 11:55 #15187
by Rick G
Replied by Rick G on topic Re:outher file formats
I believe .plt files are normally files prepared to send to a plotter, based on HPGL file format.
So a CAD program gives you the option to save in that format so it can be sent directly to a plotter.
As such they do not contain the g codes EMC would be looking for.
Can you save them in another format?
Rick G
Rick G
29 Nov 2011 12:07 #15188
by Rick G
You may also look at Chapter 22 of the User Manual for Image to G code for .png .gif .jpg files.
You can find the manual at...
Applications
CNC
EMC2 User manual
Rick G
Applications
CNC
EMC2 User manual
Rick G
29 Nov 2011 20:38 #15196
by ezboy
i can export as
ai
eps
wmf
dxf
bmp
if i export as a dxf the emage is app.
100 times too big.
ai
eps
wmf
dxf
bmp
100 times too big.
29 Nov 2011 21:31 #15199
by Rick G
If you export as dxf you will need a program to convert it to a g code that emc understands.
Take a look here...
wiki.linuxcnc.org/emcinfo.pl?Cam
Rick G
Take a look here...
Rick G
Moderators: Skullworks
Time to create page: 0.307 seconds
