Gcodetools - Inkscape's CAM extension
18 Sep 2012 15:12 - 18 Sep 2012 16:30 #24375
by 777funk
Replied by 777funk on topic Re:Gcodetools - Inkscape's CAM extension
Just edited post #24371 after more tests.
EDIT: Too weird... I just redid a few things in your code and now .NCD works but .nc doesn't.
Here's what I did:
I just changed the file types and put "Sources" in the _section since I saw other languages had Sources instead of Other.
I don't think changing "Other" to "Sources" did anything. But not sure there. Haven't tested it.
EDIT2: Some .nc files open as Plain Text and others as GCode. If I save one as GCode language it will later open with GCode.
Here's what I did:
<language id="gcode" _name="Gcode" version="2.0" _section="Sources">
<metadata>
<property name="mimetypes"></property>
<property name="globs">*.nc;*.ngc;*.ncd;*NCD</property>
<property name="block-comment-start">(</property>
<property name="block-comment-end">)</property>
</metadata>
Last edit: 18 Sep 2012 16:30 by 777funk.
19 Sep 2012 10:28 #24411
by Nick
Replied by Nick on topic Re:Gcodetools - Inkscape's CAM extension
Hmmm... I'm totally confused.
If we
Create new file + save as ngc = Text file
Create new file + save file as .nc + save as ngc = Gcode languge
Create new file + save file as .c it becomes C + save as ngc = Gcode languge
It appears that it wont change file parsing type only if saving from the text file...
If we
13 Oct 2012 02:20 #25283
by 777funk
In GEdit Is there a way to do math operations to say ALL Z-axis coordinates?
in other words shift all of the Z's up by a set amount?
17 Oct 2012 11:40 #25401
by Nick
I'm afraid no.
But you can use Regular expression extension for that.
for example, change
Z([\-\d\.\s]+)
to
Z[#<zoffset>+[\1]]
and define #<zoffset> = 10 at the top.
Or you can use parameterize Gcode postprocessor from Gcodetools to add this parameters to Gcode automaticaly.
for example, change
Z([\-\d\.\s]+)
to
Z[#<zoffset>+[\1]]
15 Feb 2013 08:58 #30082
I have been trying to use gcodetools to create lathe G-code, and I don't seem to be able to figure it out.
I have a profile in Inkscape. X is vertical, Z is horizontal.
All I seem to be able to get is a profile in XY with several Z steps (not ideal for a lathe).
Could you possibly give a step-by-step of how to create lathe G-code from a profile in Inkscape?
(And does the G-code always contain Y coordinates? That seems wrong)
Replied by andypugh on topic Gcodetools - Inkscape's CAM extension
I've remade Inkscape plug-in and want to share it .
Lathe machining
- walt_scrivens
24 Apr 2013 06:26 #33103
by walt_scrivens
Replied by walt_scrivens on topic Gcodetools - Inkscape's CAM extension
I'm having a problem with area fill. I can get the area filled in properly with the Area tool, and the drawing looks correct. When I generate the gcode, it still looks good in inkscape, but in the actual .ncg file, some paths are repeated over and over - 55 times in the attached file!
I've been deiting the duplicate paths out with Gedit, but that's tedious and unnecessary. Any ideas what I might be doing wrong?
Walt
Walt
24 Apr 2013 15:54 #33121
by Nick
Replied by Nick on topic Gcodetools - Inkscape's CAM extension
Did you fill the area with Offsets of the original path?
You should define correct "path width" Gcodetools adds (path width)/(tool diameter) paths with dinamyc offset. In fact this function is not the best choise. You can try Fill area with Zig-Zag or Spiral from Dev version, usualy it works better.
Offsets of the path is a quite complex task and some times some bugs appear. Even poverful CADs have problems with offsets, I saw bugs in Rhinoceros after offsetting paths.
The following user(s) said Thank You: walt_scrivens
- walt_scrivens
28 Apr 2013 18:32 #33322
by walt_scrivens
Thanks, Nick.
I tried Spiral, and it worked well, but with a lot of wasted motion going back to the start of a cut for a second pass (to reach final cut depth). I'll try Zig-Zag next, that might yield better results.
You mention a Dev version. I'm using 1.7 which I thought was the latest released version, although it differs significantly from the tutorials. As I gain more experience I hope to be able to help with writing/editing the tutorials. Should I be using an earlier version? I'm an old hand at computers in general but this is my first venture into CAD/CAM.
Thank you for a wonderful piece of software
Walt
Walt
29 Apr 2013 15:05 #33370
by Nick
Yes 1.7 is the latest released version. But we have improved version that is in the development. We just have no time to make a new release.
You can find dev version in the bazaar repository bazaar.launchpad.net/~gcodetools.team/gcodetools/develope/files
then create inx files by
python create_inx.py
and install the extension as usual.
Dev version has some new features and bug fixes.
The following user(s) said Thank You: jpka
Moderators: Skullworks
