CAM between Inventor and LinuxCNC
06 May 2012 18:41 #19884 by ishman
Any one here use Inventor and linuxcnc together with any CAM ? I am about to invest in mastercam X as it generates toolpaths automatically from Inventor. But there is no Post-processor for EMC2 or linuxcnc in Mastercam. Is it possible to use any Fanuc post like Mach3 is using ?
Thanks.
06 May 2012 19:32 #19885 by BigJohnT
Mastercam should have an EMC2 post processor, if not they should provide you one when you purchase it. That is what the value added (more money for your product) dealers are supposed to do for the extra money you pay them. I've used mastercam in the past and had an EMC2 post for it so I know they are out there... have you looked on the wiki for the post?
07 May 2012 00:15 - 07 May 2012 00:17 #19889 by ishman
Thanks John.
I have not asked to the dealer about it whether they will provide post processor for it or not. somebody can give me an idea how much they can ask or charge to provide the post for EMC2?
One more question that if we invest on that value added post processor then will it produce g-code for any type of machine running EMC2 as a controller ? For example Lathe, Boring Mill and Milling etc.
And I have seen wiki for the post. There is a custom made post-processor for Mastercam but we have to modify the g-code with that post.
Last edit: 07 May 2012 00:17 by ishman.
07 May 2012 06:40 #19897 by cncbasher
which changes do you make to the gcode , the mastercam post processor , can be adjusted to make this permanant ,
you most probably will end up with 2 post processors optimised for mill and lathe , as the mastercam post processor is a txt file , then then changes are minimal
let me know what changes you need and i'll have a look into it further ..
i have not had to pay extra on paying for a post processor , when your paying bucks . if they want a sale they can add it free !
07 May 2012 07:34 #19898 by ishman
Actually I was referring to a link where there is a post-processor for MasterCAM and have have mentioned that you have to change first line and some A.0 bits.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Cam_Post
That's the good news and I assume that it's not as difficult to get posts from their dealers and modify them as per our requirements in future.
Thank for your response cncbasher.
07 May 2012 07:55 #19900 by cncbasher
yes , they are easy changes to make permanant in the post processor .
11 May 2012 01:43 #19994 by JR1050
For what it is worth,there are betterr Cam programs out there for the money then Mastercam.If your goal is to generate code directly from a solid model.then you would be better off with a system that runs in Inventor itself.It seems like Hypermill does.if you have access to Solidworks,you can import your Inventor model and use any of the several cam systems that run in side Solidworks.Camworks comes to mind,it is very powerfull and about the same cost as mastercam.
I was very impressed with Visual Mill for the money,and I have several friends that love Gibbs and Featurecam.Your work will dictate your needs.Vector is a great lowbuck package,but has its limitations.My experinece with solid models is they are not as easy to work with as the cam salesman will lead you to beleive,just a word of advice.I have tried to cut both solidworks and step files in Mastercam and had poor results,I resaved the files as iges,and saw sucess.
As for the post,most posts are tweek able,a generic Fanuc post should get you going.Some systems have post generators which can be used to write a new post from scratch,its a learning curve,but its about the only way you are really going to get exactly what you want.Actually,if you dont plan on using sub routines,a Fanuc post should work fine with EMC.
Pro E used to have a version of Wildfire that ran in Linux.I dont know if Pro NC will run in Linux,but if so,I think you could get both packages for about then same 10k you are gonna spend on Mastercam.Id look at Visual mill at 5k complete.Good luck!!!
11 May 2012 06:11 #19995 by ishman
Thank you JR1050
Cam software is not like CAD. As you said it's not easy to decide which is going to help you in easy and better way. I have decided not to invest in any CAM package untill I try some of them practically with my machine.
I saw Hypermill site and they look promising. And most interesting thing is that it runs inside inventor. Can anyone give me an idea about their pricing for 5axis please ?
11 May 2012 06:50 - 11 May 2012 06:50 #19996 by ishman
I need an opinion about that isn't it a good idea to start with 3axis heekscnc and pycam initially ? Because according our road map, We need 5axis CAM after 6-8 months.
IMO going initially with heekscnc and pycam is that you don't have to struggle with post-processor and you can gather experience for better decision about your CAM investment in future.
Last edit: 11 May 2012 06:50 by ishman.
11 May 2012 10:26 #20000 by Mike_Eitel
Hi
This might be not the best implementation but at least I get some results
Just I have to delete the G28 's lines ..... otherwise I can't run the program.
Sorry I'm very short in time these days, so I simply collected a bunch of files I have and zipped them
P.S.
As fare as I remember I had to start from the version 9 ....... pst
Mike
File Name: mxcam.zip
File Size:184 KB
Moderators: Skullworks
Time to create page: 0.172 seconds
