CAD/CAM
- allenwg2005
- Topic Author
- Thank you received: 4
05 Feb 2013 07:05 #29613
by allenwg2005
CAD/CAM was created by allenwg2005
Hello EMC warriors,
I am in need of advice as to which CAD/CAM software folks out there find useful and affordable.
Over the past twelve years I have spent countless hours learning different programs only to find. issues, unwelcome changes, and insane maintenance price tags.
I have "VisualMill" on my laptop and I am about to reembark on another learning adventure, before doing so I thought I would see what (if anything) you folks might have to share on the subject.
One additional point: I'm running a Linux OS so any CAD/CAM program would need to function on that platform or in wine. I am hoping to avoid wine as it slows things down a bit, but you gota do what you gota do.
Look forward to any advise you may have.
Thanks, Allen
Thanks, Allen
02 Mar 2013 08:37 #30750
The following user(s) said Thank You: allenwg2005
02 Mar 2013 16:15 #30753
by emcPT
Can you inform for what kind of work you need a CAD/CAM?
For milling / lathe?
I only use a CAD for helping with the coordinates, but the gcode I write all by hand (except to engrave letters or numbers). Both in milling machine and lathe. I find that a CAM does not do what I want, although I never experiment those fancy stuff that cost more than 10k.
Sometimes I write a program in 100 lines that a CAM writes in 1000 lines (or more).
All that I do by hand is readable and the CAM stuff is not.
My opinion
My opinion
- allenwg2005
- Topic Author
03 Mar 2013 07:48 #30783
by allenwg2005
Replied by allenwg2005 on topic CAD/CAM
I am going to be running a router.
I'm not smart enough to write my own G-Code.
If things go as planned I would be doing some fairly complex contouring and I know I not that smart!
(Can't type to save my life)!
Sadly I'm limited to plug and play, at lest for the time being. (Limiting I know).
So many opptions for CAD/CAM it's hard to know what to pick and who or what to trust.
Thank you for your help, Allen
- Thank you received: 1370
03 Mar 2013 08:32 #30785
Replied by Todd Zuercher on topic CAD/CAM
For wood working I feel www.vectric.com/ software is very reasonably priced. However I haven't really used it.
03 Mar 2013 18:57 #30791
by Rick G
As Todd stated take a look at Vectric, also they have great tutorials that I believe you can download for free to see how to run the programs.
A friend of mine uses it for everything from simple shapes to complex engraving on contours instead of CAD CAM packages.
Rick G
Rick G
03 Mar 2013 20:59 #30798
Image-to-Gcode is free and already included in LinuxCNC. (try opening an image file instead of a G-code file in Axis)
In some cases you can probably machine direct from a rendered image of your 3D model. Though this seems like a kludge.
FreeMill is probably worth a look. They are trying to get you to buy one of their full-on products, but it has its uses.
No Linux version AFAIK. www.mecsoft.com/freemill.shtml
PyCAM is probably the most Linux-y offering out there: pycam.sourceforge.net
- allenwg2005
- Topic Author
04 Mar 2013 06:47 #30810
by allenwg2005
Andy,
I went to Pycam and tried to download the program using a terminal box.
Being new as to how all of this is done in a Linux operating system I got no where.
Can step by step instructions be found to install the program?
Thanks so much for your help, Allen
04 Mar 2013 07:01 #30811
cd ~/Downloads
wget sourceforge.net/projects/pycam/files/pyc...ycam_0.5.1-1_all.deb
sudo dpkg -i pycam_0.5.1-1_all.deb
And that's it.
You can run it from the command line by typing
pycam
Working from the command line might not be the easiest way, but I just tried this, and it workedCan step by step instructions be found to install the program?
cd ~/Downloads
And that's it.
pycam
Moderators: Skullworks
Time to create page: 0.090 seconds
