Mastercam X6 post to LinuxCnC
28 Sep 2013 17:33 #39312
by fannlow
Mastercam X6 post to LinuxCnC was created by fannlow
Hi, I'm using Mastercam X6, but as i use MPFAN.pst for posting to G-code, it is .nc format.
the linuxCnC doesn't seem to like this format...
i just downloaded the EMC2.pst from for masterCam v9, using the
Settings -> Run User Application (Alt +C) -> updatePost.dll
to update the v9 for x6, it works great!
however it still saves over to .nc file?
may I edit this file for .ngc or how should i go about doing this?
MastercamX6 -> LinuxCnC
thank you
thank you
The following user(s) said Thank You: diehtmargraumann@aol.com
28 Sep 2013 19:35 #39316
by cncbasher
Replied by cncbasher on topic Mastercam X6 post to LinuxCnC
all you need to do is to rename the file produced to .ngc
or add in the filter section of your INI FILE
PROGRAM_EXTENSION = .nc
Moderators: Skullworks
