HeeksCNC Tool Table
18 Nov 2013 02:38 #40904
by LS
HeeksCNC Tool Table was created by LS
Hello,
I have a question regarding the tool table. I'm using HeeksCNC, and I've defined all my tools in this application. I've exported a test gcode which uses two different tools.
When I run this file on LinuxCNC, it generates an error saying that Tool#46 is not in the tool table.
Okay, I know it's easy to add all my tools, but is it necessary for my case? For example, it looks like HeeksCNC has already accounted for the tool diameter/shape, so do I need to configure the LinuxCNC table with zero values for all the tools?
LS
LS
18 Nov 2013 16:47 #40928
by cncbasher
Replied by cncbasher on topic HeeksCNC Tool Table
if your going to use any cam software tooltable then make the same number of entrys in the linuxcnc tooltable +1
and make all the values 0.0 , this is preferable than just blank entrys .
19 Nov 2013 04:07 #40949
by LS
Replied by LS on topic HeeksCNC Tool Table
Great thank you.
Moderators: Skullworks
