post processor for cad cam software
05 Jun 2014 08:34 #47700
by pocamil
post processor for cad cam software was created by pocamil
hello, I am using a new software to generate woodworking stuff tool paths. The only problem is the lack of a post processor for linuxCNC and the vendor said they do not plan to add it.
So, I got a pp for mach3, maybe someone can help and configure it to work with linuxCNC, I know nothing about this kind of stuff, so any help is greatly appreciated.
thanks a lot!
Poca
thanks a lot!
Poca
* Output for MachII or MachIII with Arcs, mm
* >>>>>>> File Format Key <<<<<<<<<<<<<
* Asterisk (*) denotes Comment Lines.
* Text following * is Ignored by processor.
* Characters contained in < > are variables.
* Variables are followed with properties
* Numeric values in < > are ASCII characters.
* Variables contained in {} are commands.
* ------ Variables Used in Comments -----
* Job Name = <JobName>
* Name for Tool Path = <PathName>
* Name for Tool = <ToolName>
* Name of G-Code File = <GCodeFile>
* Name of Material = <MatName>
* Name of Toolset = <Toolset>
* Load FaceUp/FaceDown = <LoadFace>
* Material Width = <MatW>
* Material Length= <MatL>
* Ascii character =<##> where ## is char number
* ---- Variables Used by Post File --------
Start Variables
* Post File Extension
<FileExtension>
Value = txt
* Units (Inch or mm)
<Units>
Value = mm
* Start Line Numbering
<LineNumStart>
Value = 10
* Line Numbering Increment
<LineNumInc>
Value = 10
* Maximum Line Number
<LineNumMax>
Value = 999999
* Arc Length Max (if no G2, G3)
<ArcMax>
Value = 0.01
* Line Numbering
<N>
Always = Yes
Character Format = N
Numeric Format = 1.0
Factor = 1
* Material Width (Short) Axis as X
<MatAxis>
Value = Yes
* Z Zero at Bottom of Material
<ZZeroBot>
Value = No
* Y Zero at Bottom Left of Material
<YZeroBL>
Value = Yes
* Tool Number
<T>
Always = Yes
Numeric Format = 1
Factor = 1
* Spindle Speed
<S>
Always = Yes
Character Format = S
Factor = 1
* Feed Rate
<F>
Always = No
Character Format = F
Numeric Format = 1.1
Factor = 1
* Plunge Rate
<P>
Always = No
Factor = 1
* X Position
<X>
Always = No
Character Format = X
Numeric Format = 1.4
Factor = 1
* Y Position
<Y>
Always = No
Character Format = Y
Factor = 1
* Z Position
<Z>
Always = No
Character Format = Z
Factor = -1
* X Home Position
<XH>
Always = Yes
Factor = 1
* Y Home Position
<YH>
Always = Yes
Factor = 1
* Z Home Position
<ZH>
Always = Yes
Factor = -1
* Relative Arc Center I Position
<I>
Always = Yes
Character Format = I
Factor = 1
* Relative Arc Center J Position
<J>
Always = Yes
Character Format = J
Factor = 1
* Arc Radius
<Radius>
Always = Yes
Character Format = R
Factor = 1
* --------- End Variables ----------------
* --------- Commands Used ----------------
Start Commands
* Start of File (Output at start of g-code file)
{Start}
( Mozaik Output for Mach2/3 )
( <GCodeFile> )
( Material Size)
( X= <MatW>, Y= <MatL>)
( Material Name )
( <MatName>)
(Tool used in this file )
(<ToolName>)
<N>G00G20G17G90G40G49G80
<N>G70G91.1
<N>T<T>M06
<N> (Tool=<ToolName>)
<N>G00G43<ZH>H<T>
<N><S>M03
<N>(Toolpath=<PathName>)
<N>G94
<N><XH><YH><F>
* Command for Rapid Move
{RapidMove}
<N>G00<X><Y><Z>
* Command for First Feed Move
{FeedMove1}
<N>G1<X><Y><Z><F>
* Command for Feed Move (Following G0)
{FeedMove}
<N><X><Y><Z>
* Command for Plunge (Following G0)
{PlungeMove}
<N>G1<Z><P>
* Command for First CW (ClockWise) Arc
{CWArc1}
<N>G2<X><Y><I><J><F>
* Commands for CW (ClockWise) Arc
{CWArc}
<N>G2<X><Y><I><J>
* Command for First CCW (CounterClockWise) Arc
{CCWArc1}
<N>G3<X><Y><I><J><F>
* Command for CCW (CounterClockWise) Arc
{CCWArc}
<N>G3<X><Y><I><J>
*End of File ( Commands for end of File )
{End}
<N>G00<ZH>
<N>G00<XH><YH>
<N>M09
<N>M30
05 Jun 2014 13:34 - 05 Jun 2014 13:41 #47707
by ArcEye
Replied by ArcEye on topic post processor for cad cam software
Hi
Before trying to re-invent the wheel, have you checked that none of these work?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Cam_Post
Secondly, what is wrong with the output from this post processor that needs changing?
Have you tried it, what errors do you get?
A lot of mach code will run without any major problems.
On a quick scan, change the txt to ngc in the below and see where it gets you.
If you do need assistance you will need to attach some code you are converting, the resultant output and the error messages you get loading it.
<FileExtension>
Value = txt
Last edit: 05 Jun 2014 13:41 by ArcEye.
05 Jun 2014 18:19 #47714
by BigJohnT
Replied by BigJohnT on topic post processor for cad cam software
What CAM software is it?
Just guessing but the first thing I'd try is to turn off the useless line numbers.
JT
* Line Numbering
<N>
Always = No
JT
06 Jun 2014 07:33 #47739
by pocamil
Replied by pocamil on topic post processor for cad cam software
ok, this is the code the software created, its called Mozaik
and error message says:
Near line 11 of /home…..test.ngc:
Unknown g code used
not sure what to do.
( test mdf 18 S1H.NGC )
( Material Size)
( X= 1820, Y= 2700)
( Material Name )
( mdf 18 W=1,820 L=2,700)
(5mm Drill)
N10G00G20G17G90G40G49G80
N20G70G91.1
N30T1M06
N40 (Tool=5mm Drill)
N50G00G43Z-20.0000H1
N60S18000M03
N70(Toolpath=HoldDowns)
N80G94
N90X0.0000Y0.0000F3812.0
N100G00X632.1569Y14.3510Z-20.0000
N110G00Z-6.4000
N120G1Z3.0000F1525.0
N130G00Z-20.0000
N140G00Z-20.0000
N150G00X0.0000Y0.0000
N160M09
N170M30
Unknown g code used
06 Jun 2014 13:20 #47742
by ArcEye
Count down 11 lines, on line above that is G70G91.1
Look in the gcode guide
www.linuxcnc.org/docs/html/gcode/gcode.html
and you find G70 does not exist in linuxcnc.
This is what error messages are for.
Is this the raw output or processed? It still has line numbers.
Unknown g code used
Moderators: Skullworks
Time to create page: 0.159 seconds
