cncdiy usb-parallel & Linux CNC
15 Aug 2014 11:59 #49883
by lfjill
cncdiy usb-parallel & Linux CNC was created by lfjill
Hello. I bought a cncdiy usb to parallel card and some drives and stepping motors to rebuild a plasma system. I was told to use Mach3 but I want to use Linux CNC, ¿Is there somebody who have done that? ¿Do I need an extra driver to get the card recognized by Linux CNC? ¿Some suggestion?
If I get sheetcam to get the G Code of a design, is it an "all you need" application or I have besides to use Linux CNC or Mach3?
Thank you for your assistance.
Luis
Luis
15 Aug 2014 12:36 #49884
Replied by cmorley on topic cncdiy usb-parallel & Linux CNC
unfortunately USB to parallel will not work with linuxcnc.
USB is not realtime enough for us.
Chris M
Chris M
16 Aug 2014 11:05 #49915
by lfjill
Replied by lfjill on topic cncdiy usb-parallel & Linux CNC
Then how do you interface Linux CNC with stepping motors? I supposed this card was better than the parallel because that interface is old and need an obsolete parallel port (centronics) so not very fast.
Althoug it doesn't be optimal, it doesn't work at all with this cncdiy card? Have you tried with this card?
Although it be slower than the optimal? I only need to work with two axis. Are you sure it doesn´t work?
16 Aug 2014 12:42 #49917
using a real parallel port either integrated in the compouter or added from a PCI interface
or a pci/pcie port, using a interface card such as Mesa supplies
No I have not tried that card. No it will not work.
Linuxcnc can not use USB for motion control (you can use USB for other things)
The card you have purchased seems to be mach3 only
This is a bit old: wiki.linuxcnc.org/cgi-bin/wiki.pl?LinuxCNC_Supported_Hardware
and here is why USB won't work (fairly technical) wiki.linuxcnc.org/cgi-bin/wiki.pl?Emc2HardwareDesign
Chris M
Chris M
Moderators: Skullworks
Time to create page: 0.464 seconds
