nx cam post processor for linuxcnc 2.6.3
24 Sep 2014 11:32 #51513
by b2unit
nx cam post processor for linuxcnc 2.6.3 was created by b2unit
i'm trying to edit post processor with post builder for linuxcnc 2.6.3
which one is most close to g-code for linuxcnc 2.6.3 and easy to edit?
now I'm considering 2 start base for editing with default mill 3 axis in nx 9.0 and fanuc 6m.
here are g-codes from same object with different post processor.
structure is very similar but numeric display is different..
and
if you don't mind let me know which part should be edited.
thanks.
and
thanks.
- speedwizard
21 Jan 2016 17:15 #68889
by speedwizard
even it's an old thread, the answer is really simple.
Output units are inch for the one and mm for the other post.
Hope this helps,
Thorsten
Replied by speedwizard on topic nx cam post processor for linuxcnc 2.6.3
Hope this helps,
Thorsten
Moderators: Skullworks
Time to create page: 0.145 seconds
