DXF to G code Generator
15 Oct 2015 03:33 #63767
by BigJohnT
DXF to G code Generator was created by BigJohnT
I'm writing a
DXF to G code
generator in golang for fun. At this point it will take a profile sort though it then spit out a .ngc file. It's very basic at this time. I'm looking for someone to do some pre alpha testing to find problems. If you add the Feed and Z moves it will be a complete G code file.
JT
JT
- Customize IT
07 Jan 2016 16:17 #68022
by Customize IT
Replied by Customize IT on topic DXF to G code Generator
Here is a open source dxf to G code program?
Maybe these guys could help you or with your skills could build off it?
www.dakeng.com/ace.htm
- Thank you received: 5944
07 Jan 2016 23:33 #68035
Replied by tommylight on topic DXF to G code Generator
Just downloaded, will give it a run after Monday.
Regards,
Tom
Regards,
Tom
Moderators: Skullworks
Time to create page: 0.103 seconds
