Dxf2Gcode
26 Jul 2016 00:54 #78025
by Marfil
Hi Tommylight. Here you are the Christian K. 's answer.
El lunes, 25 de julio de 2016, 13:53:00 (UTC-3), Christian Kohlöffel escribió:
This Problem is due to not standard characters like ä ü ö etc. In German. Please try to put your files in another folder which does not contain any special characters.
Please check what is the current folder where you try to open the files and the folder in which dxf2gcode is located.
Regards Christian
Currently the application is running Ok. Thanks for your support.
Marfil.
I used those same links and made 2016 version work yesterday, so you give it a try.
Also i did read that and skipped as it had no solution.
On the first link you have the solution, just change the decoding to UTF8 if you are using UTF8 or to whatever you are using, most probably Latin.
Regards,
Tom
Regards Christian
Marfil.
- Thank you received: 5979
26 Jul 2016 01:02 #78026
Replied by tommylight on topic Dxf2Gcode
You are welcomed, always. Glad you made it work.
Regards,
Tom
Regards,
Tom
Moderators: Skullworks
Time to create page: 0.168 seconds
