Fusion 360 engraving using linuxcnc
- vikingsraven
08 Oct 2016 15:41 #81417
by vikingsraven
Fusion 360 engraving using linuxcnc was created by vikingsraven
Hi all,
not been on for a while. Anyway just trying out Fusion 360 Cam side of things, managed to pocket and adaptive machine, but thought i would try the engrave mode.
Am i right in thinking i will need another POST Process file for this type of operation, i see lathes are having a few issues,
Im running the latest LINUX CNC software and have a Gravograph VX85 ( i think) engraver.
Anway Fusion is creating a working path and looks good, but i keep getting
TextEngraveTest.ngc.failed files.
anyone got any ideas please.
thanks
Mark
thanks
Mark
09 Oct 2016 09:47 #81449
by pommen
Replied by pommen on topic Fusion 360 engraving using linuxcnc
I had the some thing a while back, on a mill though.
If I remember correctly i needed to change all the coolant options in the tool library to "none" before it started giving me gcode.
Dont know if you perhaps have the same problem, but might be worth a try.
/Peter
/Peter
- vikingsraven
09 Oct 2016 11:22 #81458
by vikingsraven
Replied by vikingsraven on topic Fusion 360 engraving using linuxcnc
Thanks Peter,
i was going to post its fixed i had set tool orientation instead of doing properly , noobie error.
Moderators: Skullworks
Time to create page: 0.094 seconds
