Problem EMC2 and Solid - lathe
- sharpshooterser
29 Jan 2018 06:59 #105141
by sharpshooterser
Problem EMC2 and Solid - lathe was created by sharpshooterser
Hi
I was just wondering can you fellas help me out? I have a gcode generated by Solid for a part I am working on (and it has a fanuc post-processor, its not my Solid 2015 copy, and I cant mess with asking to explore and add one that is more suitable).
It s a small handle, and it has a radius end. Now, when I start EMC2 and make a first piece, it all goes OK. When starting the same piece again after the first one is done, when the finish move on the ball radius part is cut, instead of making a radius cut, the tools moves in a taper manner, straight line, and ruins the piece (and it shows that move on preview the same way, straight pink line). If I restart the EMC2, and run it again, it cuts radius once more. If I try the second, I get taper line again. Its not much of a deal, but its boring to restart it over and over again... I have attached the code file, maybe you can shed some lite to me?
02 Feb 2018 20:03 - 02 Feb 2018 20:03 #105338
by vadoch
Replied by vadoch on topic Problem EMC2 and Solid - lathe
I think you need move first line (G0 X15 Z20) after initialize all g-code:
G0 X15 Z20
G0 T1M6G43
G0 G54 G40 G80 G97 G99
G0 X15 Z20
G0 X20 Z0.5
maybe this is due to the fact that the instrument compensation comes into effect
G0 T1M6G43
G0 X15 Z20
G0 X20 Z0.5
Last edit: 02 Feb 2018 20:03 by vadoch.
- sharpshooterser
05 Feb 2018 10:23 #105433
by sharpshooterser
Replied by sharpshooterser on topic Problem EMC2 and Solid - lathe
Thank you forcthe idea - I tried it, but it didnt work. Maybe its some problem with the controller itself (PRC 5 axis)?
Moderators: Skullworks
Time to create page: 0.090 seconds
