4-Axis indexing tool path crosses stock
27 Sep 2018 16:17 #118059
by deemoss
4-Axis indexing tool path crosses stock was created by deemoss
Hi!
I have generated g-code in Fusion360 which machines 3 faces of a cube (on a 4-axis machine, B-Axis). It seems to work, except, when the tool moves from one operation to the next, it chooses the shortest path, which means going through the stock. See video.
I am not even sure where to change this behaviour; CAM setup, post processor, LCNC?
Could you give me some pointers?
Cheers,
Dimos
Cheers,
Dimos
27 Sep 2018 16:20 - 27 Sep 2018 16:20 #118060
by tecno
Replied by tecno on topic 4-Axis indexing tool path crosses stock
Look at the simulation in F360 and do your corrections there in CAM.
Last edit: 27 Sep 2018 16:20 by tecno.
27 Sep 2018 16:38 #118064
Definitely something to fix in the CAM.
I am not at a machine with Fusion installed at the moment, so can't show you where to change this.
Replied by andypugh on topic 4-Axis indexing tool path crosses stock
28 Sep 2018 12:30 #118107
by deemoss
Replied by deemoss on topic 4-Axis indexing tool path crosses stock
Thanks guys, I will check the CAM and report on the progress.
Moderators: Skullworks
Time to create page: 0.073 seconds
