C coded dxf to g-code converter, the building process...
- twoflowers
- User is blocked
- Thank you received: 32
23 Nov 2019 18:27 #151074
by twoflowers
Replied by twoflowers on topic C coded dxf to g-code converter, the building process...
Any news on the converter? Sourcecode, maybe?
16 May 2020 21:06 #168002
by Grotius
Replied by Grotius on topic C coded dxf to g-code converter, the building process...
Source is over here : github.com/grotius-cnc/QT_cadcam
At the moment programming a new converter, that will include a pocket algoritme for milling machines.
the algortime functionality will look like : github.com/jbuckmccready/CavalierContours
But coded by me from scratch and including a spline offset algoritme.
The following user(s) said Thank You: tommylight, Joco
- Thank you received: 5944
16 May 2020 21:17 #168004
Replied by tommylight on topic C coded dxf to g-code converter, the building process...
I thought you were kidnapped by that 3 letter organisation never to be seen again !
Nice to see you back.
16 May 2020 21:44 #168008
by Clive S
Plus 1
Replied by Clive S on topic C coded dxf to g-code converter, the building process...
Plus 1
Moderators: Skullworks
