SolidCam Postprocessor Turn-mill
30 Aug 2019 11:43 #143651
by klartoon
SolidCam Postprocessor Turn-mill was created by klartoon
Hi everyone!
I am using a homade Cnc Lathe with linuxcnc, under solidworks/solidcam files. A found a postprocessor for turning some time ago. It also works for milling.
Now I would like to use the turn-mill option because need to put a mini-mill in the toolpost.
I ask you if you can give me a hand, because I can not find any way to work out the machine.
I supose I need a different postprocessor for turn-mill in solidcam. Can you help me, please,
Thank's you all,
Thank's you all,
30 Aug 2019 14:58 #143659
by pl7i92
Replied by pl7i92 on topic SolidCam Postprocessor Turn-mill
hi
from version 22 there is a Fanuc_m11 post iside that can do both
and you can setup the mashine linuxcnc interface for this post
the postprocessors output on mcode can also be modified to get the 2spindles running
Saying M140 sets C/A axis to be Joint
M141 relese to Spindle RPM M3/m4
the second spindle will be on coustom as of fanuc
in linuxcnc MASTER you can have multiple spindles
alover start with the fanuc_m11 and work your way
30 Aug 2019 17:46 #143675
by klartoon
Replied by klartoon on topic SolidCam Postprocessor Turn-mill
I really apreciate your answer. Thank's!. I am going to test it right now.
Regards,
Regards,
09 Feb 2022 18:58 #234405
by ciux_007
Replied by ciux_007 on topic SolidCam Postprocessor Turn-mill
Hello,
It is possible to share with us here, yours postprocessor for the lathe?
I have a small lathe retrofit with linuxcnc and I don't have the postprocessor.
Best regards,
Ciux
Best regards,
Ciux
Moderators: Skullworks
Time to create page: 0.134 seconds
