- GCode and Part Programs
- CAD CAM
- Importing .STL file from Solid Woks doesn't appear in tkinter in vismach?
12 Sep 2019 09:00 #144947
by Mohamed
Trying to import a Cad model of A hyprid Cnc into Vismach by using pyhton on terminal of linuxcnc, first i tried to draw just a sphere using the command " sphere(X,Y,Z,r) " and it appeared perfectly but when i try to import the cad model of a simple cylinder from solidworks using the command AsciiSTL(filename="/path.stl)m it didn't give me errors but it also didn't appear like the sphere, i tried to zoom in and out but it's just not there..
12 Sep 2019 13:39 #144963
by pl7i92
Replied by pl7i92 on topic Importing .STL file from Solid Woks doesn't appear in tkinter in vismach?
is it safed as a BIBARY File or as a ASCII only
Ascii suportet bevor master
The following user(s) said Thank You: Mohamed
12 Sep 2019 21:07 #144985
by Mohamed
Replied by Mohamed on topic Importing .STL file from Solid Woks doesn't appear in tkinter in vismach?
yes It was in binary, seems like the defult in solidWorks to export .STL as binary, so we had to configure it to export it as ASCII.
Thank you so much for this information
13 Sep 2019 07:01 #145030
by pl7i92
GLAD we coudt help you
CAN you please mark this Tread as SOLVED and close
VISMACH FILES NEED TO BE IN ASCIII
13 Sep 2019 08:09 #145033
by Mohamed
How can i mark this thread please ?
Moderators: Skullworks
- CAD CAM
Time to create page: 0.123 seconds
